  New Posts New Posts RSS Feed - True approaches
True approaches
frankbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Topic: True approaches
    Posted: 14 May 2015 at 10:13am
How does the 540 handle approaches based on true headings (i.e. in northern Canada, where magnetic variation is large).  Does the desired track and actual track and course display simply revert to True (and presumably annotate that the displayed headings are True?) If so, what about en route in that environment... are headings true or mag?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2015 at 1:59pm
The answer is both. You can switch between Mag and True bearing reference on the Aux page. The IFD540 won't automatically change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2015 at 8:36am
Thanks... that helps! So to fly an approach using true headings, I'd simply change the bearing reference, and all would look normal. (Presumably if one didn't change the bearing reference, one could still fly the approach, but it would look like a large crosswind, with the mag heading well off from the true track).
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2015 at 10:48am
Yes, that should display everything correctly.
