  New Posts New Posts RSS Feed - setup
setup
frankbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Topic: setup
    Posted: 07 Mar 2015 at 9:28am
I'm sure there's a simple answer here... I'd like to change the datablock options on the right side of the map page. If I go to Aux, Datablock Setup (using the LSK), I only see options to change the left side. How do I get to the right side??! (Specifically, I'd like to see groundspeed somewhere, and would like to add it).
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2015 at 9:35am
Use the outer ring of the bottom right knob to place your cursor where you want it on the right side of that page.  Then use the inner ring of the bottom right knob to scroll up and down the center list to pick what datablock you want there.  Repeat as required until the entire right side is set up the way you want it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2015 at 9:42am
Thanks... figured it was simple.
This page was generated in 0.135 seconds.
