  New Posts New Posts RSS Feed - ICAO flight plan codes
jhbehrens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhbehrens Quote  Post ReplyReply Direct Link To This Post Topic: ICAO flight plan codes
    Posted: 24 Jan 2015 at 10:42am
Hi
The IFD540 flight manual supplement says;
I'm wondering whether this means the PNB codes for an ICAO flight plan therefor are;
PBN/A1B2L1C2D2S1
Does anyone know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2015 at 10:31am
Reference AIM section 5.1.9 table 5-1-6, we think S1 approaches are okay.
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 5:00am
my Commander is equipped with:
2x IFD540
Aspen 1000 PFD PRO (so that gives me also baro?)
dme
adf
mode s transponder (GTX330)
So I presume that my codes would be:
SBDFGRY/S
PBN /A1L1B2D2S2
S2 because of the combination with Aspen?
D2 (and C2) because one is permitted to fly RNAV1 and RNAV2 procedures?
And I presume that to comply with T1/T2 a part 91 operator needs additional approvals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 7:36am
I don't know about the RNP (Sx) settings.
Tx definitely not, RTF is not supported.
Craig767 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2015 at 8:17pm
Here is what I came up with for ICAO
Equipment: B,L,O,Y
Surveillance: B1,L
PBN: C2,D2,S1
Does this look good for 540/340 combo. Foreflight says iPad does not count for ADS-B in.
Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2015 at 2:47pm
Foreflight may say that.
FAA in a letter to John Collins based on his query said different, i.e. non-panel mounts are ok for ADS-B in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2015 at 12:02pm
OK thanks, will switch to ADSB in. Makes more sense that way also.
