  New Posts New Posts RSS Feed - Suggestion - Low Fuel
rdawson View Drop Down
Release 9 Insiders
Release 9 Insiders
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdawson Quote  Post ReplyReply Direct Link To This Post Topic: Suggestion - Low Fuel
    Posted: 24 Aug 2010 at 4:25pm
There must be a place on this site for suggestions, but I cannot find it so here is mine ---
I can’t be the only guy with this problem.
First, let’s acknowledge that fuel gauges are essentially worthless; in 40 + years of flying, I have always ignored them and kept track of fuel with fuel flow and time. Nonetheless, the Cirrus has fuel gauges and, worse, integrates them to the R9. The problem is what R9 does with the information. If the gauge reads below a certain level, up pops a warning – a warning that requires at the least an acknowledgement. Then, when the gauge shows a bit more fuel, the warning goes away only to reappear on the next giggle of the fuel sender.
The proper response, it seems to me, would be to latch the warning, or at least design in a bunch of hysteresis. We can be reasonably sure that no fuel is being added to the tank while airborne. (I did not purchase the air-to-air refueling option.) As it is now, I get (literally) dozens of warnings on a given flight – some of which require attention at busy times such as on an approach.
Am I the only guy with this problem?
AviMike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviMike Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 11:29am
I agree with your assessment of the fuel gauges and them being used as fuel 'planning' devices.  The fuel tanks in a Cirrus have discrete outputs back to R9 that indicate a low and a zero fuel level.  Those inputs are what we use to trigger the Low Fuel caution and warnings that used to go to the annunciator panel.
R9 handles the discretes just like they were handled in the annunciator panel except that we delay the display of the message until it is received continuously for 5 seconds.  It is especially problematic when there is extended high pitch or roll of the aircraft.  When the discrete is cleared then we take down alert.  We apply hysteresis to other parameters but didn't to this input.  We have thought of ways to improve it 'flashing' like latching it when it goes off the first time.  We've had some other thoughts, like handling it differently in maneuvers but haven't thought through all the use cases.
You are not the only one who has brought up this issue.  Would you like it to be latched after it goes off the first time?
Release 9 Insiders
Release 9 Insiders
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdawson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 12:51pm
Latching would be ideal. Fuel in the tank never increases. Therefore "when the discrete is cleared" can be safely ignored.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviMike Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 12:57pm
I should have been more clear.  Latching it would mean keeping the caution or warning visible after the first time it is detected.  Taking the alert down would not 'certifiable' or safe since the condition could still be present and the alert is gone.
Release 9 Insiders
Release 9 Insiders
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdawson Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 2:34pm
It is I should have been more clear. By ingoring "when the discrete is cleared" implies that the warning would remain for the duration of the session. I agree that the alert should not be taken down - it is the alert that would be latched.
Release 9 Insiders
Release 9 Insiders
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdawson Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2011 at 10:23pm
Has Avidyne given any more thought to latching the low fuel warning? There was no mention in the description of the current software release. Will this be included in a future release?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviMike Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 3:18pm
Hi Rick,
This feature did not make the list in R9.2.3.  In fact, this release is a very small update to fix a couple of IFD software issues that were seen in the field.  Release 9.3 is the next major functionality release with SynVis.  Currently, this low fuel suggestion is not on the R9.3 list either.  It will be included in a future release but we need to get through the big-ticket items first.
- Mike
Release 9 Insiders
Release 9 Insiders
Post Options Post Options   Thanks (0) Thanks(0)   Quote rdawson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2011 at 4:54pm
Thanks for the update. Keep up the great work!
