  New Posts New Posts RSS Feed - Screen Protector
Screen Protector
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Topic: Screen Protector
    Posted: 16 Oct 2014 at 10:44pm
Is there any type of screen protector that Avidyne suggests for the touch screen 540. I'm wondering if anything like the iPad type protectors are recommended or available??
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2014 at 6:32pm
No, we don't endorse any screen protectors.  In fact, some will actually damage the touch screen glass.
It'll be interesting to see if any users come up with something neat but for now, we definitely don't recommend anything.
In the past, on other Avidyne products, folks have used stuff then sent it in for service and since the glass was so damaged because of it, the warranty was void.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2014 at 6:39pm
Good to know...Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2014 at 7:20pm
What about cleaning the glass...
I have to know...
the plane comes home MONDAY!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2014 at 8:34pm
What do  you recommend to CLEAN the screen surface? Just a bit of soap and water;  glasses/lens cleaner (which is soap/water and a bit of alcohol), or what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2014 at 10:21pm
Take a look at page 6-39 of the pilot guide.
We recommend a soft lint-free cloth such as 3M Ultra-Brite Cloth #2011 or similar.   For a cleaning solution, try some de-ionized water or reagent-grade acetone or isopropyl alcohol.
Do NOT use methanol or nasty stuff like that.
This page was generated in 0.305 seconds.
