  New Posts New Posts RSS Feed - AXP340 Transponder Specifications
John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Quote  Post ReplyReply Direct Link To This Post Topic: AXP340 Transponder Specifications
    Posted: 28 Dec 2012 at 5:04pm
I note that the Avidyne Brochure references "elementary" surveillance capability. I contacted "Warren" online yesterday, seeking some understanding, and I was rather put-out at his response. Can you explain what "surveillance" is; how is it distinguished from "interrogation"; and what is the difference between "elementary surveillance" and "enhanced surveillance"? Following these comments, could you compare the Becker remote unit to the AXP340 in terms of capabilities, costs, and ease of use?
Thanx,
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2012 at 9:37am
Hi John,
Sorry about the inadequate response from Tech Support.   Let me call in Dean Ryan who knows much more about this than I.  He's been off for the holidays and we'll post a more complete answer when he returns.
Here's what I know about the two:
Elementary Surveillance = Mode S
Enhanced Surveillance is a European mandate and was meant for aircraft with a max takeoff gross weight above 5700 kg, with a greater than 250 KTAS cruise speed, operating in EASA territory.  I believe those Enhanced Surveillance devices transmit data to include IAS, mag heading, mach number, roll angle, track angle rate, true track angle, ground speed, and selected altitude.
Like I said, let me call in an expert to provide a more complete answer for you.
dryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dryan Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 6:42pm
Surveillance is a generic term used to describe a system or device that is used to monitor the location of aircraft.  All transponders are surveillance devices in that they receive interrogations and send data in response.  The term surveillance (whether elementary or enhanced) does not imply that a transponder is capable of interrogating other aircraft or providing traffic data to the pilot.
The term interrogation is typically used to describe a signal that is transmitted to query the transponder on board an aircraft.  Interrogations are used by the secondary surveillance radar sites and by some airborne traffic alerting devices such as TAS and TCAS.
Some transponders are able to transmit more data than others.  For instance, the older style Mode A/C transponders only send altitude and squawk code, whereas Mode-S transponders include a unique aircraft ID and potentially many other additional data elements.
Elementary surveillance means that a transponder does not support the Mode-S transponder Enhanced Surveillance (EHS) capabilities.  This is a distinction defined primarily for the European aviation community.  A Mode-S transponder compliant with the enhanced surveillance capabilities will be capable of transmitting a number of additional data elements such as aircraft magnetic heading and vertical rate.  It should be noted that these extra capabilities also necessitate that there is a source for that data on board the aircraft and that the source is connected to the transponder.
John View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2013 at 11:25pm
Thanx for the clear and concise explanation. Could you comment on the comparison I requested between the AXP340 and the remotely mounted Becker (which Avidyne, at one time, promoted to be included as part of one of your systems)? Can foreign made Transponders (Mode "S") handle USA ADS-B? Also, I note that some twins fly with dual Garmin GTX-330's - why would anyone spend the money or waste the panel space? Does it have anything to do with RVSM requirements? Possibly, there is a reliability issue with the Garmin Transponders?
Hopefully, some other pilots out there will benefit from these questions being answered - I have certainly heard numerous conversations with these questions being booted about.
Again, Thank You
John
Post Options Post Options   Thanks (1) Thanks(1)   Quote dryan Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2013 at 11:42am
Can foreign made Mode-S transponders handle USA ADS-B?
Yes; Mode-S transponders are designed and certified using an internationally approved design specification and will operate properly world-wide.
Why do some pilots equip dual transponders?
I believe this is simply for redundancy.  A functioning transponder is required equipment for operations in many air spaces; therefore I believe some pilots prefer to have a backup, especially those flying high performance aircraft that will frequent Class A/B/C airspace.  I don't believe there is any RVSM requirement for dual transponders, and I am unaware of any reliability issues that have led pilots to equip two transponders.
How does the AXP340 compare with the Becker BXP6402?
There are no significant differences between the AXP340 and the BXP6402 technical specifications; however the Becker BXP6402 does not currently comply with the ADS-B out TSO (TSO-C166b).  Obviously the AXP340 is panel mounted versus the remote mounted BXP6402.
TurboPA30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboPA30 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2013 at 2:33am
When will there be a remote TXP that the IFD540 can control? That was always a big plus of the CNX80, and Garmin now offers it again on the GTNs. Transponder is really a waste of panel space.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2013 at 9:46am
Not initially.  We have deferred that capability out of the initial release for the IFD540 for time-to-market reasons.
We do agree that the 540 is a  great place to do all transponder control and display and free up panel space so we plan to add it back in in a later release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2014 at 8:25am
waiting patiently for the announcement....... soon?
I hope it interfaces to two Avidyne position sources (master and a hot backup)  at the same time.
Edited by tony - 05 Oct 2014 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2014 at 8:37am
Yes, soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TurboPA30 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2014 at 8:47am
Remote TXP and MLX770 support are the 2 most important pending issues....
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2014 at 6:41am
Steve is the MLB100 the announcement you were referring to or is there another one comng?  I was hoping for a remote transponder that would interface with the 540 and 440.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2014 at 8:15am
Tony,
The MLB100 announcement is the only one we've made this week.   A remote mount transponder that interfaces with the IFD540/440 is a good idea but we have not made any product announcements in that area.
Steve
Edited by AviJake - 10 Oct 2014 at 8:17am
This page was generated in 0.088 seconds.
