  New Posts New Posts RSS Feed - 10.3.2.2
10.3.2.2
kempj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kempj Quote  Post ReplyReply Direct Link To This Post Topic: 10.3.2.2
    Posted: 02 Aug 2025 at 7:23pm
After the installation of the 10.3.2.2 software I am seeing the following:
IFD 100 "429 Data not received"
G5 HSI "Not receiving RS-232 data"
GTX 345 transponder "NO 1090 ES"
I was careful to check the 2 settings in maintenance mode and the recommended ones in flight mode per section 3.1.  I did complete the steps to verify the software load in 5.1. Can you point me to the configuration settings that could have changed that would cause this?
Kemp J
Victor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2025 at 1:50am
Has 10.3.2.2 been released?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:04pm
Yes!  See this post.
jwellman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwellman Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 49 minutes ago at 9:21am
You may have already addressed this as the post is a couple of weeks old.  But here's what happened:
Your ARINC 429 and RS232 settings likely were cleared.  This happened on mine as well.  I had created the backups from the main page but should have also flipped through the settings and recorded a video to manually restore those settings.  The restore did not appear to work...maybe it's version specific or maybe it restores other things.
Thankfully I had a video of the settings page from about a year ago when we initially installed the IFD440 but some things have changed in our setup since then...so it's about 90% working at the moment.
Hope you were able to get yours sorted!
Jared
1954 E35 Bonanza
IFD440
GFC500
