  New Posts New Posts RSS Feed - Release 10.3.2.2
Release 10.3.2.2
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Topic: Release 10.3.2.2
    Posted: 05 Aug 2025 at 11:57am
Here are the release notes for 10.3.2.2
Bug Fixes
  • Fixed bug that prevented user waypoints with special characters in the name from being loaded
  • Fixed display of FIS frequencies in the FSS frequency list
  • Fixed known issues with interface to GFC autopilots
  • Fixed GAMA 429 output to prevent the display of active waypoint from being delayed on Aspen PFD
  • Fixed bug that allowed selection of an approach when every transition contained an RF leg
  • Fixed computation of radial/distance user waypoint position when based on a fix with no mag var
  • Fixed GPS Select discrete unexpectedly going invalid
  • Fixed issues affecting the reliability of flight plan upload from Foreflight
  • Fixed annunciations when approaches have no LNAV minima
  • Fixed display units on multi-engine fuel flow display
  • Fixed flight plan depiction on the map for some SIDs
  • Fixed incorrect ETA at destination when a visual approach is selected
  • Fixed display of frequency list on newer IFD440s
  • Fixed EGPWS outputs at low speeds
  • Fixed Info page display of fuel types available
  • Fixed lateral offset behavior when on a direct-to
  • Fixed display of green radial line on the map when station has no VOR component
  • Fixed maintenance mode issue that caused brightness to be dim until lighting page was accessed
 New Features / Improvements
  • Added support for Vantage12
  • Improved VOR sensitivity of the radio
  • Added support for Bluetooth LE keyboards
  • Improved maintenance mode discrete I/O page
  • Added ability to clear alerts via remote switch
  • Added support for NVIS-enabled IFDs
  • Added support for Aspen display of Enroute VNAV
  • General
    • Added capability to retain Data/Plan/Map tab settings between power cycles
    • Modified communication between units to show database mismatch, etc.
    • Added support for displaying remote secondary weather frequencies
  • Aux
    • Improved manual dimming control
    • Improved user profile management
    • Added “notices” to alert counts datablock
    • Shared “system wide” user settings between IFDs
  • Map
    • Added ability to create a user waypoint by touching the map
    • Added ability to select direct-to waypoint from the map
    • Added map layer for user waypoints
    • Map tab setting is retained across power cycles
    • Added map layer for comm airspace types (TMZ, RMZ, Mode C, CFZ, MBZ)
  • FMS
    • Added aural chime for next leg alert
    • Improved performance of GPS steering on approach
    • Improved visual approach capability when paired with KFC225 autopilot
    • Improved stored route management
      • Routes shared on command
      • Allow selection of the sort order
      • Enhanced display format
    • Added “delete all” capability for user waypoints
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:01pm
10.3.2.2 is complete!  We are doing a limited rollout to validate that it is working as expected.  Once through that process, we will make it generally available.  If you are specifically affected by a problem that would be resolved by the installation of 10.3.2.2 (e.g. GFC autopilot interface issues), then contact tech support for access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 3:32pm
Nice. I'm interested in the Foreflight flight plan upload fix.
Once this version is generally released, will I be able to get a copy to have it installed by my A&P/IA?
Edited by HenryM - 05 Aug 2025 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 4:20pm
Yes, that's the plan.
gherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gherb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:44am
There is an issue with the IFD540, when flying a flight plan on autopilot GPSS, when a new flight plan is active (reverse flight plan on return, for example), and the IFD100 still has the old flight plan, when you open the iPad, the IFD100 flight plan takes priority over the IFD540 and the plane immediately tries to initiate a course reversal. Has this been resolved?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 12:05pm
Came here to ask this. There are several other IFD100 bugs that I dearly hope get fixed as part of this release cycle, but this is the most obnoxious one.
Gary Lutchansky View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 1:51pm
Good news. The upcoming IFD100 release does resolve this issue.
P.S. I'm a member of the software engineering team at Avidyne.
Edited by Gary Lutchansky - 06 Aug 2025 at 1:53pm
kempj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kempj Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:24pm
Gary,
I installed 10.3.2.2 last week in my IFD440.  Since the upgrade, I am unable to get flight plans to sync between the IFd100 app and the panel mount IFD440.  The IFD100 apps connects and functions fine as far as frequency tuning, etc so its not a connection issue.  If you create a flight plan in the app it doesn't appear in the panel mount and if you create in the panel mount it doesn't appear in the IFD100 app.  The databases are also the same on both sides.  I reported this today to Randall Edwards and he informed me he would report this to the software engineering team.  Do you think the new upcoming IFD100 app will address this or is this an unknown issue.  It did not exist with 10.3.1.2
Kemp Johnson
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 10:01pm
Kemp,
Yes, the upcoming release of IFD100 will work with your updated IFD hardware. The method of exchanging data over WiFi for 10.3.2.2 is more secure. Because of this, the new and the former methods of communication are not compatible.
Coming soon!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote kempj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 9:30am
Gary,
Since I am unable to create/manage/monitor flight plans in the ifd100 app do you know how long it will be before I can download the new version of IFD100? Is there a way to beta test the IFD100 app before it is released in a general way?
Kemp Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 10:07pm
  • That is huge, if it is what I think it is. Previously you restricted enroute VNav to only display on IFD550 units. Personally I always thought that was a huge misstep.
    So, now with an IFD540 (or 440?), the enroute VNav indication will be shown on the ASPEN? If so, that limitation has been mitigated!
    Edited by oskrypuch - 09 Aug 2025 at 10:08pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 10:32pm
    I still don't see a fix for the standard resolution terrain warning depiction. It is unusable currently in standard resolution, and I have had to turn it completely off, otherwise the map becomes unreadable during departure and approach.
    Edited by oskrypuch - 10 Aug 2025 at 1:13pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 2:52pm
    Steve, can you confirm which G5 software release Avidyne has TESTED the new software with?  I want to ensure nothing breaks.
    Can you describe in detail what the GFC autopilot fixes are?  What are the errors and what does it fix.  Mine currently works fine.
    Edited by Gring - 10 Aug 2025 at 2:53pm
    jimmyz80 View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 3:06pm
    100%, I went back to using the Honeywell EGPWS in my plane since the terrain features on my IFDs are more of a hazard than a help. Glad to see the dimming bus issue fixed though.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 5:27pm
    VNAV wasn't specifically limited to the IFD550, but the lack of supporting PFDs may have made it seem that way.  Yes, we worked with Aspen to have them display VNAV from the IFD.  However, I'm not sure of their release schedule.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2025 at 8:22pm
    The Garmin G5 also displays the VNAV carrot.  The GFC500 autopilot will not control VNAV though.  It allows arming, and annunciates VNAV in white, but does not engage.
    I also had my G5s updated to 8.27 software today during the IFR cert, so we'll see how that works with the new release.
    Edited by Gring - 11 Aug 2025 at 8:23pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 8:40am
    Our G5 is at 5.30
    Some GFC autopilots wouldn't go into approach mode.  We determined the cause was an error in the MapMx stream, which we fixed.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 10:04am
    Thank you for the information, but come on, I can't believe that you guys are testing your software with Garmin software that is YEARS old.  There are 19 releases between 5.20 and the current version.  In fact, there isn't a 5.30 listed, just the jump from 5.20 to 5.50.  There must be some mistake with that release number, can you verify with your team?
    I had not heard about that error with the GFC500, only on the GFC600 autopilots.  I have heard about the GFC500 autopilots flying left of course by one dot.  Can you confirm this was fixed too?
    I instruct in a number of Bonanza airplanes and have seen some of these issues with my clients.  I have no idea why mine works just fine though.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 10:15am
    It was not specific to GFC, but we did make some improvements to the roll steering command while on approach to address such steady state deviations.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 10:37am
    Pictures don't lie...    Garmin G5 software version 5.30 is for experimental G5 installations only.  It isn't for certified installations.
    Would you guys be willing to go back and update your G5 to the current 8.27 certified version and retest it with the 10.3.2.2 software to ensure proper operations?
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2025 at 2:14pm
    We don't plan on updating our G5 and retesting at this point.
    PA23 View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 10:46am
    Looking through the list of bug fixes etc, what does this one mean?
    "Fixed GPS Select discrete unexpectedly going invalid"
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 12:11pm
    Originally posted by PA23 PA23 wrote:
    ...what does this one mean?
    The IFD has a "GPS Select" discrete output.  The behavior of that output varies based on configuration in maintenance mode during installation.  In some instances, the IFD was not asserting that discrete as expected when there was a pending approach (indicated by a cyan mode in the nav source selection on the upper right corner of the IFD).
    Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 12:30pm
    Sort of, but still -- although the 550 WILL display the VNav path itself, on its pages (with no separate supported PFD), the 540 will not. That is the point I was making.
    There is no logical reason that a VNav progess SI could not have been added to the IFD MAP page, it is a normal constituent on "big boy" navigational displays roughly equivalent to the IFD MAP page (not just PFDs). To say the 540 does not have a "PFD" page, really isn't germane. Perhaps it was some sort of workload/certification issue.
    Edited by oskrypuch - 13 Aug 2025 at 4:43pm
    Victor View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2025 at 12:56pm
    Re we did make some improvements to the roll steering command while on approach to address such steady state deviations, can you please confirm that this is not only a fix for G5 and GFC500 configurations, but also a fix for G3X and GFC500 configurations.
    Edited by Victor - 14 Aug 2025 at 1:00pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2025 at 8:24pm
    Steve,< ="chrome-extension://ldinpeekobnhjjdofggfgjlcehhmanlj/inpage.js" id="leather-provider">
    I tend to agree with Gring. My G5 is running release 8.25 and it would be good to have some confirmation that the new release has been tested with a recent G5 software.
    JEDEI120 View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote JEDEI120 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 46 minutes ago at 9:26am
    I not seeing these listed new features in 10.3.2.2 for my IFD440:
    • Map touch to create user waypoint
     Direct-to waypoint from map
     Stored route sorting
     Enhanced stored route display
    Also note this new release broke the IFD100 app.  IFD100 no longer communicates flight plans.  Neither from the IFD100 app to IFD or vice versa!
    Edited by JEDEI120 - 20 hours 43 minutes ago at 9:29am
    Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 19 minutes ago at 9:53am
    I'm also in that same situation...running certified G5 release 8.27 and associated firmware released for GFC500. My current setup works fine. I don't want to mess that up.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 58 minutes ago at 8:14pm
    Originally posted by Victor Victor wrote:
    Re: we did make some improvements to the roll steering command while on approach to address such steady state deviations, can you please confirm that this is not only a fix for G5 and GFC500 configurations, but also a fix for G3X and GFC500 configurations.
    We did no specific testing with the G3X.  However, the changes we made for that were not specific to any particular configuration.  So if you're experiencing the same issue, I expect this to resolve it.
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 40 minutes ago at 8:32pm
    Hoping you got a copy of the updated Pilot's Guide for your IFD.  If not, please email or PM me.  I expect the 10.3.2.2 PG to be available for general download in the near future.  But here's a short version of what you should do to exercise those specific features.
    • To create a user waypoint by touching the map, the user waypoints layer must be visible on the map (see your setup page for the conditions required to see that layer).  If that layer is visible, then touching the map for a second or so will create the waypoint
    • To go direct-to from the map, start a direct-to using the -D-> button while the map is showing.  Then touch a fix on the map to put the identifier in the -D-> dialog.
    • Stored route sorting is accomplished using the bottom button on the stored routes list page.  The button says "Sort By".
    • Enhanced stored route display is a fancy way of saying that the layout of each row is slightly different, the default route names are better, and there are operation icons on each row.
    An updated IFD100 app will also be available soon.
    This page was generated in 0.049 seconds.
