  New Posts New Posts RSS Feed - Release 10.3.2.2
Release 10.3.2.2
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Topic: Release 10.3.2.2
    Posted: 05 Aug 2025 at 11:57am
Here are the release notes for 10.3.2.2
Bug Fixes
  • Fixed bug that prevented user waypoints with special characters in the name from being loaded
  • Fixed display of FIS frequencies in the FSS frequency list
  • Fixed known issues with interface to GFC autopilots
  • Fixed GAMA 429 output to prevent the display of active waypoint from being delayed on Aspen PFD
  • Fixed bug that allowed selection of an approach when every transition contained an RF leg
  • Fixed computation of radial/distance user waypoint position when based on a fix with no mag var
  • Fixed GPS Select discrete unexpectedly going invalid
  • Fixed issues affecting the reliability of flight plan upload from Foreflight
  • Fixed annunciations when approaches have no LNAV minima
  • Fixed display units on multi-engine fuel flow display
  • Fixed flight plan depiction on the map for some SIDs
  • Fixed incorrect ETA at destination when a visual approach is selected
  • Fixed display of frequency list on newer IFD440s
  • Fixed EGPWS outputs at low speeds
  • Fixed Info page display of fuel types available
  • Fixed lateral offset behavior when on a direct-to
  • Fixed display of green radial line on the map when station has no VOR component
  • Fixed maintenance mode issue that caused brightness to be dim until lighting page was accessed
 New Features / Improvements
  • Added support for Vantage12
  • Improved VOR sensitivity of the radio
  • Added support for Bluetooth LE keyboards
  • Improved maintenance mode discrete I/O page
  • Added ability to clear alerts via remote switch
  • Added support for NVIS-enabled IFDs
  • Added support for Aspen display of Enroute VNAV
  • General
    • Added capability to retain Data/Plan/Map tab settings between power cycles
    • Modified communication between units to show database mismatch, etc.
    • Added support for displaying remote secondary weather frequencies
  • Aux
    • Improved manual dimming control
    • Improved user profile management
    • Added “notices” to alert counts datablock
    • Shared “system wide” user settings between IFDs
  • Map
    • Added ability to create a user waypoint by touching the map
    • Added ability to select direct-to waypoint from the map
    • Added map layer for user waypoints
    • Map tab setting is retained across power cycles
    • Added map layer for comm airspace types (TMZ, RMZ, Mode C, CFZ, MBZ)
  • FMS
    • Added aural chime for next leg alert
    • Improved performance of GPS steering on approach
    • Improved visual approach capability when paired with KFC225 autopilot
    • Improved stored route management
      • Routes shared on command
      • Allow selection of the sort order
      • Enhanced display format
    • Added “delete all” capability for user waypoints
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 12:01pm
10.3.2.2 is complete!  We are doing a limited rollout to validate that it is working as expected.  Once through that process, we will make it generally available.  If you are specifically affected by a problem that would be resolved by the installation of 10.3.2.2 (e.g. GFC autopilot interface issues), then contact tech support for access.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 3:32pm
Nice. I'm interested in the Foreflight flight plan upload fix.
Once this version is generally released, will I be able to get a copy to have it installed by my A&P/IA?
Edited by HenryM - 05 Aug 2025 at 3:32pm
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2025 at 4:20pm
Yes, that's the plan.
gherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gherb Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:44am
There is an issue with the IFD540, when flying a flight plan on autopilot GPSS, when a new flight plan is active (reverse flight plan on return, for example), and the IFD100 still has the old flight plan, when you open the iPad, the IFD100 flight plan takes priority over the IFD540 and the plane immediately tries to initiate a course reversal. Has this been resolved?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 12:05pm
Came here to ask this. There are several other IFD100 bugs that I dearly hope get fixed as part of this release cycle, but this is the most obnoxious one.
Gary Lutchansky View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 1:51pm
Good news. The upcoming IFD100 release does resolve this issue.
P.S. I'm a member of the software engineering team at Avidyne.
Edited by Gary Lutchansky - 06 Aug 2025 at 1:53pm
kempj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kempj Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 9:24pm
Gary,
I installed 10.3.2.2 last week in my IFD440.  Since the upgrade, I am unable to get flight plans to sync between the IFd100 app and the panel mount IFD440.  The IFD100 apps connects and functions fine as far as frequency tuning, etc so its not a connection issue.  If you create a flight plan in the app it doesn't appear in the panel mount and if you create in the panel mount it doesn't appear in the IFD100 app.  The databases are also the same on both sides.  I reported this today to Randall Edwards and he informed me he would report this to the software engineering team.  Do you think the new upcoming IFD100 app will address this or is this an unknown issue.  It did not exist with 10.3.1.2
Kemp Johnson
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Lutchansky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2025 at 10:01pm
Kemp,
Yes, the upcoming release of IFD100 will work with your updated IFD hardware. The method of exchanging data over WiFi for 10.3.2.2 is more secure. Because of this, the new and the former methods of communication are not compatible.
Coming soon!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote kempj Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2025 at 9:30am
Gary,
Since I am unable to create/manage/monitor flight plans in the ifd100 app do you know how long it will be before I can download the new version of IFD100? Is there a way to beta test the IFD100 app before it is released in a general way?
Kemp Johnson
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 10:07pm
  • That is huge, if it is what I think it is. Previously you restricted enroute VNav to only display on IFD550 units. Personally I always thought that was a huge misstep.
    So, now with an IFD540 (or 440?), the enroute VNav indication will be shown on the ASPEN? If so, that limitation has been mitigated!
    Edited by oskrypuch - 09 Aug 2025 at 10:08pm
    Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2025 at 10:32pm
    I still don't see a fix for the standard resolution terrain warning depiction. It is unusable currently in standard resolution, and I have had to turn it completely off, otherwise the map becomes unreadable during departure and approach.
    Edited by oskrypuch - 10 Aug 2025 at 1:13pm
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 2:52pm
    Steve, can you confirm which G5 software release Avidyne has TESTED the new software with?  I want to ensure nothing breaks.
    Can you describe in detail what the GFC autopilot fixes are?  What are the errors and what does it fix.  Mine currently works fine.
    Edited by Gring - 10 Aug 2025 at 2:53pm
    jimmyz80 View Drop Down
    Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2025 at 3:06pm
    100%, I went back to using the Honeywell EGPWS in my plane since the terrain features on my IFDs are more of a hazard than a help. Glad to see the dimming bus issue fixed though.
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 60 minutes ago at 5:27pm
    VNAV wasn't specifically limited to the IFD550, but the lack of supporting PFDs may have made it seem that way.  Yes, we worked with Aspen to have them display VNAV from the IFD.  However, I'm not sure of their release schedule.
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 5 minutes ago at 8:22pm
    The Garmin G5 also displays the VNAV carrot.  The GFC500 autopilot will not control VNAV though.  It allows arming, and annunciates VNAV in white, but does not engage.
    I also had my G5s updated to 8.27 software today during the IFR cert, so we'll see how that works with the new release.
    Edited by Gring - 18 hours 4 minutes ago at 8:23pm
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 47 minutes ago at 8:40am
    Our G5 is at 5.30
    Some GFC autopilots wouldn't go into approach mode.  We determined the cause was an error in the MapMx stream, which we fixed.
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 23 minutes ago at 10:04am
    Thank you for the information, but come on, I can't believe that you guys are testing your software with Garmin software that is YEARS old.  There are 19 releases between 5.20 and the current version.  In fact, there isn't a 5.30 listed, just the jump from 5.20 to 5.50.  There must be some mistake with that release number, can you verify with your team?
    I had not heard about that error with the GFC500, only on the GFC600 autopilots.  I have heard about the GFC500 autopilots flying left of course by one dot.  Can you confirm this was fixed too?
    I instruct in a number of Bonanza airplanes and have seen some of these issues with my clients.  I have no idea why mine works just fine though.
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 12 minutes ago at 10:15am
    It was not specific to GFC, but we did make some improvements to the roll steering command while on approach to address such steady state deviations.
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 50 minutes ago at 10:37am
    Pictures don't lie...    Garmin G5 software version 5.30 is for experimental G5 installations only.  It isn't for certified installations.
    Would you guys be willing to go back and update your G5 to the current 8.27 certified version and retest it with the 10.3.2.2 software to ensure proper operations?
    Status: Online
    Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 13 minutes ago at 2:14pm
    We don't plan on updating our G5 and retesting at this point.
