Release 10.3.2.2 |
Post Reply ![]() |
AviSteve ![]() Admin Group ![]() ![]() Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2334 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Aug 2025 at 11:57am |
Here are the release notes for 10.3.2.2 Bug Fixes
10.3.2.2 is complete! We are doing a limited rollout to validate that it is working as expected. Once through that process, we will make it generally available. If you are specifically affected by a problem that would be resolved by the installation of 10.3.2.2 (e.g. GFC autopilot interface issues), then contact tech support for access.
HenryM ![]() Senior Member ![]() Joined: 13 Oct 2017 Location: Texas Status: Offline Points: 506 |
Nice. I'm interested in the Foreflight flight plan upload fix. Edited by HenryM - 05 Aug 2025 at 3:32pm |
Yes, that's the plan.
gherb ![]() Newbie ![]() ![]() Joined: 17 Sep 2015 Location: New Orleans Status: Offline Points: 26 |
There is an issue with the IFD540, when flying a flight plan on autopilot GPSS, when a new flight plan is active (reverse flight plan on return, for example), and the IFD100 still has the old flight plan, when you open the iPad, the IFD100 flight plan takes priority over the IFD540 and the plane immediately tries to initiate a course reversal. Has this been resolved?
paulr ![]() Senior Member ![]() Joined: 24 Jan 2014 Status: Offline Points: 566 |
Came here to ask this. There are several other IFD100 bugs that I dearly hope get fixed as part of this release cycle, but this is the most obnoxious one.
Gary Lutchansky ![]() Moderator Group ![]() Joined: 12 Oct 2023 Location: Melbourne, FL Status: Offline Points: 5 |
Good news. The upcoming IFD100 release does resolve this issue. P.S. I'm a member of the software engineering team at Avidyne.
Edited by Gary Lutchansky - 06 Aug 2025 at 1:53pm |
kempj ![]() Newbie ![]() Joined: 10 Feb 2025 Location: NC Status: Offline Points: 6 |
Gary,
I installed 10.3.2.2 last week in my IFD440. Since the upgrade, I am unable to get flight plans to sync between the IFd100 app and the panel mount IFD440. The IFD100 apps connects and functions fine as far as frequency tuning, etc so its not a connection issue. If you create a flight plan in the app it doesn't appear in the panel mount and if you create in the panel mount it doesn't appear in the IFD100 app. The databases are also the same on both sides. I reported this today to Randall Edwards and he informed me he would report this to the software engineering team. Do you think the new upcoming IFD100 app will address this or is this an unknown issue. It did not exist with 10.3.1.2 Thanks, Kemp Johnson |
Kemp,
Yes, the upcoming release of IFD100 will work with your updated IFD hardware. The method of exchanging data over WiFi for 10.3.2.2 is more secure. Because of this, the new and the former methods of communication are not compatible. Coming soon! Gary
Gary,
Since I am unable to create/manage/monitor flight plans in the ifd100 app do you know how long it will be before I can download the new version of IFD100? Is there a way to beta test the IFD100 app before it is released in a general way? Thanks, Kemp Johnson
oskrypuch ![]() Senior Member ![]() Joined: 09 Nov 2012 Location: CYFD Status: Offline Points: 3064 |
That is huge, if it is what I think it is. Previously you restricted enroute VNav to only display on IFD550 units. Personally I always thought that was a huge misstep. So, now with an IFD540 (or 440?), the enroute VNav indication will be shown on the ASPEN? If so, that limitation has been mitigated! * Orest
Edited by oskrypuch - 09 Aug 2025 at 10:08pm |
I still don't see a fix for the standard resolution terrain warning depiction. It is unusable currently in standard resolution, and I have had to turn it completely off, otherwise the map becomes unreadable during departure and approach. * Orest Edited by oskrypuch - 11 hours 29 minutes ago at 1:13pm |
Gring ![]() Senior Member ![]() Joined: 30 Dec 2011 Location: Kingston, NY Status: Offline Points: 744 |
Steve, can you confirm which G5 software release Avidyne has TESTED the new software with? I want to ensure nothing breaks.
Can you describe in detail what the GFC autopilot fixes are? What are the errors and what does it fix. Mine currently works fine. Edited by Gring - 9 hours 49 minutes ago at 2:53pm |
jimmyz80 ![]() Senior Member ![]() ![]() Joined: 24 Jul 2016 Location: Folsom, CA Status: Offline Points: 107 |
100%, I went back to using the Honeywell EGPWS in my plane since the terrain features on my IFDs are more of a hazard than a help. Glad to see the dimming bus issue fixed though.
Post Reply ![]() |
