  New Posts New Posts RSS Feed - Release 10.3.2.2
Release 10.3.2.2
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Topic: Release 10.3.2.2
    Posted: Yesterday at 11:57am
Here are the release notes for 10.3.2.2
Bug Fixes
  • Fixed bug that prevented user waypoints with special characters in the name from being loaded
  • Fixed display of FIS frequencies in the FSS frequency list
  • Fixed known issues with interface to GFC autopilots
  • Fixed GAMA 429 output to prevent the display of active waypoint from being delayed on Aspen PFD
  • Fixed bug that allowed selection of an approach when every transition contained an RF leg
  • Fixed computation of radial/distance user waypoint position when based on a fix with no mag var
  • Fixed GPS Select discrete unexpectedly going invalid
  • Fixed issues affecting the reliability of flight plan upload from Foreflight
  • Fixed annunciations when approaches have no LNAV minima
  • Fixed display units on multi-engine fuel flow display
  • Fixed flight plan depiction on the map for some SIDs
  • Fixed incorrect ETA at destination when a visual approach is selected
  • Fixed display of frequency list on newer IFD440s
  • Fixed EGPWS outputs at low speeds
  • Fixed Info page display of fuel types available
  • Fixed lateral offset behavior when on a direct-to
  • Fixed display of green radial line on the map when station has no VOR component
  • Fixed maintenance mode issue that caused brightness to be dim until lighting page was accessed
 New Features / Improvements
  • Added support for Vantage12
  • Improved VOR sensitivity of the radio
  • Added support for Bluetooth LE keyboards
  • Improved maintenance mode discrete I/O page
  • Added ability to clear alerts via remote switch
  • Added support for NVIS-enabled IFDs
  • Added support for Aspen display of Enroute VNAV
  • General
    • Added capability to retain Data/Plan/Map tab settings between power cycles
    • Modified communication between units to show database mismatch, etc.
    • Added support for displaying remote secondary weather frequencies
  • Aux
    • Improved manual dimming control
    • Improved user profile management
    • Added “notices” to alert counts datablock
    • Shared “system wide” user settings between IFDs
  • Map
    • Added ability to create a user waypoint by touching the map
    • Added ability to select direct-to waypoint from the map
    • Added map layer for user waypoints
    • Map tab setting is retained across power cycles
    • Added map layer for comm airspace types (TMZ, RMZ, Mode C, CFZ, MBZ)
  • FMS
    • Added aural chime for next leg alert
    • Improved performance of GPS steering on approach
    • Improved visual approach capability when paired with KFC225 autopilot
    • Improved stored route management
      • Routes shared on command
      • Allow selection of the sort order
      • Enhanced display format
    • Added “delete all” capability for user waypoints
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 10 minutes ago at 12:01pm
10.3.2.2 is complete!  We are doing a limited rollout to validate that it is working as expected.  Once through that process, we will make it generally available.  If you are specifically affected by a problem that would be resolved by the installation of 10.3.2.2 (e.g. GFC autopilot interface issues), then contact tech support for access.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 39 minutes ago at 3:32pm
Nice. I'm interested in the Foreflight flight plan upload fix.
Once this version is generally released, will I be able to get a copy to have it installed by my A&P/IA?
Edited by HenryM - 19 hours 39 minutes ago at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 51 minutes ago at 4:20pm
Yes, that's the plan.
gherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gherb Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 27 minutes ago at 9:44am
There is an issue with the IFD540, when flying a flight plan on autopilot GPSS, when a new flight plan is active (reverse flight plan on return, for example), and the IFD100 still has the old flight plan, when you open the iPad, the IFD100 flight plan takes priority over the IFD540 and the plane immediately tries to initiate a course reversal. Has this been resolved?
