  New Posts New Posts RSS Feed - G3x with 540?
G3x with 540?
frankbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Topic: G3x with 540?
    Posted: 09 Jul 2025 at 11:52am
I bought a plane (C-182) six months ago with a Garmin 530, G3x, and GFC 500.  I swapped out the 530 for an Avidyne 540, and have had serious issues with the G3x: Obstacles appear and disappear on the screen, when I'm at altitude, and the screen flickers frequently, to white and back to normal.
Does anyone else have this combination?   Does it work ok?
Victor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2025 at 5:50pm
Yes and it works well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 12:18pm
Victor…
Can you tell me more… i.e. any particular settings you’ve made to make it work?  Since your’s works well and mine doesn’t, I’m trying to understand what might make the difference.  For example, what software level is on your 540?  Your obstacle and terrain warnings are normal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Victor Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2025 at 5:04pm
540 software is the latest, no issues with obstacle and terrain behaviour. All settings were done during installation by avionics tech.
It sounds to me like your issues might be standalone with your G3X rather than anything to do with the 540.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2025 at 10:41am
Thanks.  You may be right, tho apparently Garmin makes no effort to make its G3x compatible with Avidyne.  But thanks for the info.
AndyMeyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyMeyer Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 16 minutes ago at 9:33pm
I'm also flying the a 540 and G3X.
G3X gets Navigation (CDI, etc.) from the 540, but GPS position, NavData, obstacles, etc. are internal to the G3X. Try shutting down the IFD when you're experiencing the problem to replicate it. That'll give you more info about what's going on. (verify that it's not the 540 as we're guessing.)
Andy
This page was generated in 0.046 seconds.
