  New Posts New Posts RSS Feed - GI 275 EIS integration with IFD540
B2C2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B2C2 Quote  Post ReplyReply Direct Link To This Post Topic: GI 275 EIS integration with IFD540
    Posted: 2 hours 46 minutes ago at 4:07pm
I'm in the process of installing two GI 275 EIS units in my skymaster to replace a failing EDM 760. The 760 was connected to the 540 and provides Fuel Flow information as well as fuel remaining that the 540 uses to show fuel and flight time remaining as well as range rings which I like. The issue is the GI 275 apparently has an ethernet connection, while the IFD 540 is ARINC 429. I have found an adapter that appears to make this conversion, but I was wondering if others have solved this problem and if so how.
This page was generated in 0.195 seconds.
