  New Posts New Posts RSS Feed - Adding a second IFD
Adding a second IFD
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Topic: Adding a second IFD
    Posted: 24 Apr 2025 at 1:49pm
I put a single IFD440 in my plane after I bought it. That left me with one IFD440 and one GNS430W. I just replaced the GNS with a used IFD440. It's set to sys id 2 and cross-sync etc appears to be configured properly. However, I can't load databases onto it.
First attempt was with the databases I downloaded earlier this week. I loaded them onto unit 1 with no problem. After the shop installed unit 2, I tried using that same stick-- no go.
I then went into the Jepp website and added the second unit's serial number, relaunched JDM, redownloaded, and still no go.
What's the trick to get a database download that will be loadable onto both units?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 2:00pm
Answering my own question, it looks like all I needed was a DSF that set the paid options correctly for the unit with my tail number. As soon as I installed that, I was able to load the databases without any trouble.
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 10:50am
Geeze, 11 minutes, you didn't give anybody a chance to give you the answer :)
glad you got it figured out
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 12:40pm
Oh, don't worry, I have plenty of other questions!
Today's episode…
In my prior config, I could load an approach (visual or otherwise) on the IFD and tune an ILS, if available, on the 430W. The loaded approach on the IFD would drive the CDI on my Aspen, and as soon as I hit the button on the Garmin to flip it to VLOC, then my GI106 gives me the ILS signal.
Now that I have two IFDs, and CrossSync is turned on, I can't figure out how to do this. Whatever approach I activate on IFD 1 is also active on the other one, and in my ground tests, it looks like if I manually tune the ILS and hit the button on IFD2, that doesn't do what I want either.
One possible solution, I guess, is to disable CrossSync but I don't want to do that. Is there another way to get the behavior I had with the dissimilar units?
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 3:00pm
Perhaps you could explain what you “want” the IFDs to do? If you tune #1 to an ILS frequency, it will provide the signal and sensing to that Navaid when selected on your PFD. You can also have a different Navaid tuned on #2 without impacting what’s on #1. You can manually change #2 from GPS to VLOC using the knob on the top right, without effecting #1, just like you did with the GNS.
Syncing the two units means that they have a single approach loaded and activated. If you want different sequenced approaches available on each unit, you probably don’t want to keep them crossynced.
There is another alternative, if you want the units to share information like traffic sensor input, but don’t want to keep the flight plans in sync; just keep the #2 unit one database update behind the #1 unit. This keeps them from sharing flight plan information, but still allows them to share other inputs. Obviously, you need to be sure that the latest data is used on the primary IFD for approaches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 7:25am
I wanted to shoot a video of what the units do yesterday. In cruise, just before starting my descent into KGTR, I loaded (but did not activate) the visual approach for 18 in the #1 unit and then selected the ILS frequency for the ILS 18 in the #2 unit. When I pushed the #2 unit's OBS button, the upper-right corner of both units changed to say "OBS -> xxx" with the heading. I shrugged, landed, and went about my business. I noticed during startup on the way home that my newly installed #2 unit's config page showed a difference between the displayed OBS value and the value on the CDI, so I recalibrated it.
On the way home, I loaded the visual 36L at KHSV and tuned the ILS 36L on the #2 nav. When tower cleared me for the approach, I activated the visual. At that point, both units indicated "Visual" as the selected nav mode, and pressing the OBS on the #2 unit did nothing. I learned this morning that you can't change the nav source (the note on the top of page 5-9 on the pilot's guide explains this).
I'm away from the plane for the next few days but I'll experiment some more this weekend.
Edited by paulr - 28 Apr 2025 at 10:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 7:48pm
I’m still not understanding why you are loading a Visual approach and tuning an ILS. Why not just load and activate the ILS approach, getting either GPS guidance to one of the IAFs, or just “vectors”, which gives you a lateral course line to the final approach course to fly.
When you activate the ILS approach, the IFD will both tune the ILS frequency for you, and determine when to transition from GPS to VLOC on its own. No need to switch sources manually. No need to use OBS mode.
Edited by Melohn - 29 Apr 2025 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 9:04pm
That was just an example; my habit is to always load the ILS on the #2 nav for runways that have it, no matter what approach type (if any) I'm actually flying. I know I can do it the way you suggest but that's not what I'm trying to accomplish.
If it helps, just ignore what I'm doing with the #1 navigator; I want to tune the ILS on the #2 nav and have the #2 CDI driven by it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 11:49pm
Turn, don’t push the top right knob until the top right display reads VLOC. Then tune whatever you want on the #2 VLOC receiver, and you have what you want. The VLOC setting should remain after power off.
This page was generated in 0.041 seconds.
