  New Posts New Posts RSS Feed - Traffic & Weather from Dynon SkyView - Solved.
bradthepilot View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Topic: Traffic & Weather from Dynon SkyView - Solved.
    Posted: 25 Jan 2025 at 10:07pm
I've seen this issue pop up from time to time:  How do I get ADS-B data from my Dynon SkyView system to display on my IFD 440/540 via Wifi?   The answer is usually something along the lines of "Dynon uses extended GDL90", and having some experience implementing products using the GDL90 protocol, I decided to investigate.
After some examination of WiFi traffic, I found the core problem and built some code to prove the hypothesis.   The core issue is that the SkyView system doesn't send a 'heartbeat' message as outlined in the GDL90 protocol description; it only sends 'traffic report' and 'uplink' messages.    The solution was to build some code on a small embedded device that receives the wifi messages from Dynon and forwards them, unchanged, to the IFD.   Additionally, this device sends a heartbeat message once per second in accordance with the GDL90 specification.    The result is traffic and weather from my Dynon system was displayed on my IFD540 without issue.   There is no evidence of any kind of "enhanced" or "extended" GDL90 being produced by the Dynon system - it's just missing some of the required items.
The heartbeat message is important to the integrity of the system; something that simply relies on the presence of traffic (or uplink) reports cannot differentiate between no traffic (or uplink) reports and a failed sensor.   The heartbeat message makes that differentiation possible, and it would appear Avidyne has the correct implementation in this case.
I have been in touch with Dynon on this issue, but if this is something that affects you and you'd like to get traffic and weather from your SkyView system displayed on your IFD, contact Dynon and reference the above information.   Their product manager is aware of the issue and likely just needs to know that it's a feature desired by their customers.
Brad Benson
RV-6A N164BL
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 11:53am
would you be open to sharing the code to re-broadcast the ADSB traffic (on github or whatever).
I'd be very interested in that ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 5:51pm
Sorry, the code is not available for various reasons.   But it is quite simple.   All it needs to do are two things:
1) Forward any UDP messages received on port 4000 to the IFD, and
2) Once per second, send a GDL90 heartbeat message to the IFD.
Do both of those things, and you'll get weather and traffic on your IFD as provided by Dynon SkyView.
Brad Benson
RV-6A N164BL
bspatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bspatz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2025 at 1:55pm
I can confirm (via packet sniffing and custom EFB reception code) my new Dynon (16.7.2 certified) is not sending GDL90 Heartbeat or Ownship messages over WiFi, although I see Traffic_Report and Uplink messages.  And I agree these are required per my reading of the GDL90 spec.
I haven't yet reported to Dynon as I'm awaiting my forum account to be activated, but I will add my voice to yours.  With whom at Dynon have you been communicating?
https://www.faa.gov/sites/faa.gov/files/air_traffic/technology/adsb/archival/GDL90_Public_ICD_RevA.PDF
This page was generated in 0.150 seconds.
