  New Posts New Posts RSS Feed - Density Altitude
Density Altitude
IanJay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanJay Quote  Post ReplyReply Direct Link To This Post Topic: Density Altitude
    Posted: 12 Jan 2025 at 8:52pm
My G5s have an OAT probe that displays density altitude while I’m on the ground until I take off. I haven’t found anything in the IFD pilot manual that mentions DA  so I figured I go out on a limb and ask if the IFD has any way of displaying DA while in flight. Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 11:53am
On the AUX - UTIL - Calculators page, there is an Air Data Calculator. If your G5's are providing air data info to your IFD like they do in my plane, the only adjustment that may be necessary would be to adjust the BARO field manually. Density ALT is read on the lower right of the Air Data Calculator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IanJay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2025 at 12:45pm
Thanks!
