  New Posts New Posts RSS Feed - Replacing TAS605 with a TAS605A
peterh337 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh337 Quote  Post ReplyReply Direct Link To This Post Topic: Replacing TAS605 with a TAS605A
    Posted: 29 Dec 2024 at 5:28pm
Has anyone here done this?
Comparing the two IMs raises all kinds of interesting and subtle issues.
The 605 has no documented "laptop" config (although obviously it must contain a microprocessor etc). The 605A has extensive config, and is obviously a PC board (even has a USB port, although it is undocumented).
Other subtle things are e.g. why P2 (the big 78 way connector) has been provided when in most installations all the required signals are duplicated on the old P1 (25 way). In an upgrade situation it would be silly to rewire the P1 plug to the P2 plug (which is probably a really pricey Positronic job, with $1 each for the crimp pins, FWIW :) ).
Another curious one is that the micro appears to be scanning all the RS232 ports for the string "command" on a continuous basis, and when it sees this, that port becomes the config port. This is fine but (I am an embedded system hardware/software dev, industrial electronics) is really quite unusual! They sort of try to steer you to using P4 though.
I currently have a 605, installed in 2012. The upgrade is avionics shop performed but they are just wiremen really.
Another Q is more complicated, and may be nonsense in the USA context: does anyone here have direct experience with whether a 605A shows targets with SIL=0 on your display device and what is that display device? I am pretty sure (from Support) the 605A will pick these up but some display devices (probably Garmin, fed via RS232) will strip them out. ARINC429-fed displays cannot strip them out because the packets don't carry that info. SIL=0 is "uncertified" ADS-B OUT but is widely used in Europe; there is a ton of oddball boxes, Raspberry PI based, which people fly with, with their Mode C/S transponder firmly turned off :)
Thank you for any info.
Edited by peterh337 - 29 Dec 2024 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 6:30pm
I sent my TAS620 in for the /A upgrade.  I don't believe there was any additional wiring added at the time.  I did notice that my traffic which was really only reliable 10-15NM is now good to 25-30NM.  I don't see any obvious other differences.
Edited by Gring - 29 Dec 2024 at 6:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh337 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2024 at 11:27pm
They must have added the WAAS GPS input - without that you get no ADS-B IN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2024 at 12:21am
You’re right. I had that added as part of a larger avionics upgrade about 6months later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh337 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2025 at 1:31pm
I can see how somebody pulled out your 620 and put in a 620A, and the only change was adding the RS232 WAAS GPS wiring.
But reading the combined IM for the two boxes, you would never wire it up that way.
One can literally do the above and merely add the GPS input via the 78 way connector, not even touching the other cabling.
