  New Posts New Posts RSS Feed - IFD Dimming after Database Update
gremlin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Topic: IFD Dimming after Database Update
    Posted: 03 Sep 2024 at 2:08pm
Since my IFD440's were updated to 10.3.1.2 I have a persistent and annoying problem
after I update the Nav and Obstacle databases on any cycle the IFD's reboot and they're both Dim, instead of being full brightness. I have to do the dance to "Download logs" and reboot into maitenance mode then go to the dimming screen and then they pop to full brightness and work from then out for every reboot until I do the next update. Every single time I have to do this dance.
To begin with there was a PIN on the settings so I ran the reset procedure and now the values shown in the config screen is correct, and all I have to do is go to that page, I don't have to change anything then it all just works.
Any ideas, it's not unworkable but it's an annoying extra step every DB update.
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 2:25pm
I'd suggest starting with setting the lighting page to a known good configuration just in case something is FUBAR there.  Below is what I'm using in my IFD440 which I got it from somebody on this forum and tweaked it slightly for my tastes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 2:39pm
@PA23 appreciate that and will double check, I actually use DIMBUS not photocell on mine, and as I said above it works entirely, until a DB update, then it fails, and simply swapping to that page it will all work again until the next DB update, I don't actually have to change anything.
jimmyz80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 9:31pm
Just chiming in to say to say that I have this exact same problem. Dimming works as configured/expected until you do a database update. Then it breaks until you just go back into maintenance mode and look at the lighting page. Then it fixes everything back up again until the next database update. I made a video today of me reproducing the issue and will be opening a support case.
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2024 at 3:12pm
I guess I'll wait to see the video, but that's certainly an odd one.  I load databases all the time and haven't noticed such behavior.  Do you both have the same database coverage?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2024 at 3:20pm
Check out case #PS00134823 and I've included a google drive link with the video. I just double checked my coverage and it's listed as North America.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2024 at 4:25pm
Same North America, happens every single time, there's a discussion on the Cirrus forums and three of us currently have exactly this behaviour. I have not seen the video from Jimmz80 but his repro steps are the same as mine. And it happens every single time to both IFD's.
I even tried reformatting the key I used for the IFD's in case it had a left over config file that was tripping it up, same result.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2024 at 4:49pm
@AViSteve So one thing that came up on the COPA forums the units that are doing this are possibly all using "DimBus" and not "Photocell" for the dimmer, what's your demo unit using?
ansond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ansond Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 8:54pm
I have also seen this behavior... after the DB update, I would go back into the configuration page to the lighting section and, when I landed on that section, the screen would light back up... its almost like landing on that section "resets" the configuration somewhere within the IFD... flaky.
I ended up switching to "photocell" vs. the "dimming bus" and that seems to have helped a bit.
Doug
N208LG
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 9:11am
I usually keep it on manual, so I'll have to give it a try using the dimming bus.
Edited by AviSteve - 09 Sep 2024 at 9:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 11:48am
That would be great to test, it does seem to be common, and I much prefer to have control over it and have it match the other instruments as it has since I bought them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2024 at 3:24pm
Same here, since everything in the Cirrus is controlled from the dimming bus. It's nice to have the IFDs follow along as well, vs. having them do their own thing based on a photocell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 7:46pm
I noticed when I had my recent update I only had to go to the configurations page for it to correct itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2024 at 1:53pm
@AviSteve so have you managed to reproduce this in house? It's been several weeks and would at least like to know they have an in house repro of this issue that several of us seem to have with every up date.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2024 at 12:01pm
I have tried it here in my office and have been unable to reproduce it.  I've looked through the software for some weird connection, but was unable to find any (as I suspected).  Colleagues in Boston have tried it and were able to reproduce it just once.  We're all pretty busy on Vantage at this point, so this problem is lower on the totem pole, but we're not ignoring it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ansond Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2024 at 3:25pm
Curious @AviSteve... did you try to repro it in a G1/G2 Cirrus using the dimming bus in there?  I am just wondering if perhaps the issue involves a specific kind of dimming circuit... I can repro mine every time I do the DB update... its very reliable in terms of reproduction ability.
Doug
N208LG
PS: So glad ya'll were not significantly impacted by the hurricane!!
Post Options Post Options   Thanks (2) Thanks(2)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2024 at 7:52am
I haven't specifically tried that.  I'll get over to the hangar sometime soon and give it a shot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 6:00pm
This does happen to me on every single database update at this point in time, and we have enough other people demonstrating it that it should be reproducible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 12:38pm
SO @AviSteve, I had someone else on COPA reach out to me that this is happening to them as well. they also are using this on Dim bus, has anyone made an attempt to reproduce this issue in house with the dimbus set?
n789am View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote n789am Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2024 at 12:55pm
Hi all, I've been having this same issue for about 1-1.5 years or so as well, requiring me to go into the settings page showing the dim settings to get the settings present their to persist after each database update. For the first 5-6 months I assumed I just had incorrect settings that weren't suited to the proper transition levels, brightness settings or curves, but after a number of us were speaking on the Cirrus forums it appeared that this issue is more widespread than an individual user or two. My settings are perfect with the exception of after I apply a database update. Any guidance on resolution would be much appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 5:08pm
It must be more than _just_ the DimBus.  I've been using DimBus for ~10 years and have never observed this behavior, most recently on both IFD540 and 550 running v10.3.1.2.
One difference I notice is that PA23 and n789am are using "Proportional" curve, whereas I'm using AviCurve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n789am Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2024 at 5:35pm
Avicurve had no impact other than the curve wasn’t ideal and was still too bright at night and didn’t provide an even distribution through my dimmer range. I wanted half brightness to be roughly half way through my brightness range rather than being 80% bright. Also I’ve had this behavior with the Mx input settings photo or dimbus. I keep my user settings on dimbus though. FWIW I have 2 user profiles but would be surprised if that had any impact.
I really can’t tell it is an issue during the day because it’s bright enough but at night getting stuck at the high end of the brightness range is just annoying. This all seems to have started with 10.3.1.2 and possibly after I had to use the unlock for the password I never set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:15am
Another difference I noticed is that I've got a Piper 12V system vs. the reports here are from Cirrus 28V systems...  🤷🏻‍♂️
In case it's helpful, here are my settings (used in both the 540 and 550 that do not exhibit the behavior):
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 45 minutes ago at 10:35am
Yes we have, but it's not the highest priority thing going on at this point.  I tried it on the Cirrus and was still unable to reproduce it.  However, we have the still experimental 10.3.2.2 software loaded, so it's not apples-to-apples.  Perhaps that's good news, but I'd still like to understand the root cause of the problem even if it magically cured itself.  We have another airplane in the hangar that has 10.3.1 and I just haven't had time to go test it over there.  If it is voltage related, then that may not yield fruit either because that airplane is 14V.  Rest assured, though, we haven't given up trying to figure out what's going on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gremlin Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 37 minutes ago at 4:43pm
Thanks for the update, from 35+ years of professional software experience I've never seen a bug just fix itself, that it's not occurring in a more recent build unless they re-wrote the subsystem it's a part of will generally just mean that an unintialised variable has been moved from one stack location to another, and something else will fail that's not as obvious. Hopefully you'll have a chance to try on the current release build and still have that source and information to debug it there.
