  New Posts New Posts RSS Feed - Re-Synching IFD-Foreflight-IFD
Twicetwins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Twicetwins Quote  Post ReplyReply Direct Link To This Post Topic: Re-Synching IFD-Foreflight-IFD
    Posted: 04 Oct 2023 at 8:05am
I'm learning my new equipment. Yesterday, I sent my Foreflight flight plan to the panel. After a while, I changed to go try things at a different airport. I entered a new flight plan into my 540 and sent it to my iPad running FF. Then just to see how it would work, I sent what was on my iPad back to the panel. And it went back to the original flight plan. So then I went into Foreflight and deleted my original flight plan both on the map page and on the flights page. Tried it again and still the old flight plan popped up on the 540. I had to delete my original flight plan from the 540 in order for the new flight to be the displayed flight plan. What an I doing wrong?
rolfe_tessem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 10:37am
When you send a FP from Foreflight, it does not replace the active plan, it appears in Routes.
Rolfe
vas4avidyne View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote vas4avidyne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 3:30pm
Speaking of which, I have a feature suggestion. When a flight plan is uploaded from Foreflight, there's a pop up message that says something like "Route Ready" (or some such). It would be nice if we could click on it and get taken directly to the new route (or have the route selected when one switches to the appropriate page). Unless I am missing something, I have found it to be a bit of a pain to find the newly uploaded route. Or, tag it is some fashion to show it's new. If the new route has the same origin destination pair as other routes in my list, I find that I have to click into each one to find the correct one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2023 at 10:22am
Good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 4:52pm
Next release will contain a big change to the way that stored routes are handled.  One of the new features is a means to sort the list in different ways, including by age.  That should alleviate the problem of finding a route that has just been uploaded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vas4avidyne Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2023 at 5:07pm
That's awesome, Steve!
You know I have to ask - when (approx) do you think this next release will be available?
Vas
Post Options Post Options   Thanks (1) Thanks(1)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 5:51pm
Vas, you already know the obligatory reply! ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote vas4avidyne Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 12:36am
LoL :-)!
MarcDMcD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarcDMcD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 7:02pm
I agree, it is a pain sometimes to find the correct new route when the default names are the same.  Renaming the route is one solution, but the names are limited to approx 12 characters.  Tagging duplicate route names by sequential number might be a solution, or showing recently loaded routes at the top of the alphabetical list
McD
