Forum Home Forum Home > Company News > Company News
  New Posts New Posts RSS Feed - Avidyne website glitch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Topic: Avidyne website glitch?
    Posted: 25 Jul 2023 at 11:32pm
Trying to access the Avidyne.com website on any of my devices (Win11 laptop using Chrome or Edge, Android phone and tablet using Chrome) results in many screens of text looking like what's pasted below.
What's up with that?
Infusionsoft\Http\HttpException Object ( [message:protected] => Client error: `POST https://api.infusionsoft.com/token` resulted in a `400 Bad Request` response: (truncated...) [string:Exception:private] => [code:protected] => 400 [file:protected] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/vendor/infusionsoft/php-sdk/src/Infusionsoft/Http/GuzzleHttpClient.php [line:protected] => 74 [trace:Exception:private] => Array ( [0] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/vendor/infusionsoft/php-sdk/src/Infusionsoft/Infusionsoft.php [line] => 318 [function] => request [class] => Infusionsoft\Http\GuzzleHttpClient [type] => -> ) [1] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/infusionsoft/class-warranty-calculator-infusionsoft-helper.php [line] => 251 [function] => refreshAccessToken [class] => Infusionsoft\Infusionsoft [type] => -> ) [2] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/infusionsoft/class-warranty-calculator-infusionsoft-helper.php [line] => 176 [function] => refreshExpiredToken [class] => Warranty_Calculator_Infusionsoft_Helper [type] => -> ) [3] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/infusionsoft/class-warranty-calculator-infusionsoft-helper.php [line] => 118 [function] => checkIsAuthStatus [class] => Warranty_Calculator_Infusionsoft_Helper [type] => -> ) [4] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/includes/class-warranty-calculator.php [line] => 185 [function] => __construct [class] => Warranty_Calculator_Infusionsoft_Helper [type] => -> ) [5] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/includes/class-warranty-calculator.php [line] => 89 [function] => define_infusionsoft_hooks [class] => Warranty_Calculator [type] => -> ) [6] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/warranty-calculator.php [line] => 78 [function] => __construct [class] => Warranty_Calculator [type] => -> ) [7] => Array ( [file] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/warranty-calculator.php [line] => 82 [function] => run_warranty_calculator ) [8] => Array ( [file] => /home/webs/avidyne/public_html/wp-settings.php [line] => 428 [args] => Array ( [0] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/warranty-calculator.php ) [function] => include_once ) [9] => Array ( [file] => /home/webs/avidyne/public_html/wp-config.php [line] => 98 [args] => Array ( [0] => /home/webs/avidyne/public_html/wp-settings.php ) [function] => require_once ) [10] => Array ( [file] => /home/webs/avidyne/public_html/wp-load.php [line] => 50 [args] => Array ( [0] => /home/webs/avidyne/public_html/wp-config.php ) [function] => require_once ) [11] => Array ( [file] => /home/webs/avidyne/public_html/wp-blog-header.php [line] => 13 [args] => Array ( [0] => /home/webs/avidyne/public_html/wp-load.php ) [function] => require_once ) [12] => Array ( [file] => /home/webs/avidyne/public_html/index.php [line] => 17 [args] => Array ( [0] => /home/webs/avidyne/public_html/wp-blog-header.php ) [function] => require ) ) [previous:Exception:private] => GuzzleHttp\Exception\ClientException Object ( [request:GuzzleHttp\Exception\RequestException:private] => GuzzleHttp\Psr7\Request Object ( [method:GuzzleHttp\Psr7\Request:private] => POST [requestTarget:GuzzleHttp\Psr7\Request:private] => [uri:GuzzleHttp\Psr7\Request:private] => GuzzleHttp\Psr7\Uri Object ( [scheme:GuzzleHttp\Psr7\Uri:private] => https [userInfo:GuzzleHttp\Psr7\Uri:private] => [host:GuzzleHttp\Psr7\Uri:private] => api.infusionsoft.com [port:GuzzleHttp\Psr7\Uri:private] => [path:GuzzleHttp\Psr7\Uri:private] => /token [query:GuzzleHttp\Psr7\Uri:private] => [fragment:GuzzleHttp\Psr7\Uri:private] => ) [headers:GuzzleHttp\Psr7\Request:private] => Array ( [User-Agent] => Array ( [0] => GuzzleHttp/6.3.3 curl/7.68.0 PHP/7.4.3 ) [Host] => Array ( [0] => api.infusionsoft.com ) [Authorization] => Array ( [0] => Basic aHh4ajY2NWFhdWRyajl5c2o0MnlmZHc1OmZRY0FHRWZnZjQ= ) [Content-Type] => Array ( [0] => application/x-www-form-urlencoded ) ) [headerNames:GuzzleHttp\Psr7\Request:private] => Array ( [user-agent] => User-Agent [host] => Host [authorization] => Authorization [content-type] => Content-Type ) [protocol:GuzzleHttp\Psr7\Request:private] => 1.1 [stream:GuzzleHttp\Psr7\Request:private] => GuzzleHttp\Psr7\Stream Object ( [stream:GuzzleHttp\Psr7\Stream:private] => Resource id #11 [size:GuzzleHttp\Psr7\Stream:private] => 71 [seekable:GuzzleHttp\Psr7\Stream:private] => 1 [readable:GuzzleHttp\Psr7\Stream:private] => 1 [writable:GuzzleHttp\Psr7\Stream:private] => 1 [uri:GuzzleHttp\Psr7\Stream:private] => php://temp [customMetadata:GuzzleHttp\Psr7\Stream:private] => Array ( ) ) ) [response:GuzzleHttp\Exception\RequestException:private] => GuzzleHttp\Psr7\Response Object ( [reasonPhrase:GuzzleHttp\Psr7\Response:private] => Bad Request [statusCode:GuzzleHttp\Psr7\Response:private] => 400 [headers:GuzzleHttp\Psr7\Response:private] => Array ( [content-type] => Array ( [0] => application/json ) [x-request-id] => Array ( [0] => d1579249-d04c-4403-90da-5875120559c3 ) [content-length] => Array ( [0] => 134 ) [date] => Array ( [0] => Wed, 26 Jul 2023 03:29:17 GMT ) [Via] => Array ( [0] => 1.1 google ) [Alt-Svc] => Array ( [0] => h3=":443"; ma=2592000,h3-29=":443"; ma=2592000 ) ) [headerNames:GuzzleHttp\Psr7\Response:private] => Array ( [content-type] => content-type [x-request-id] => x-request-id [content-length] => content-length [date] => date [via] => Via [alt-svc] => Alt-Svc ) [protocol:GuzzleHttp\Psr7\Response:private] => 1.1 [stream:GuzzleHttp\Psr7\Response:private] => GuzzleHttp\Psr7\Stream Object ( [stream:GuzzleHttp\Psr7\Stream:private] => Resource id #13 [size:GuzzleHttp\Psr7\Stream:private] => 134 [seekable:GuzzleHttp\Psr7\Stream:private] => 1 [readable:GuzzleHttp\Psr7\Stream:private] => 1 [writable:GuzzleHttp\Psr7\Stream:private] => 1 [uri:GuzzleHttp\Psr7\Stream:private] => php://temp [customMetadata:GuzzleHttp\Psr7\Stream:private] => Array ( ) ) ) [handlerContext:GuzzleHttp\Exception\RequestException:private] => Array ( ) [message:protected] => Client error: `POST https://api.infusionsoft.com/token` resulted in a `400 Bad Request` response: (truncated...) [string:Exception:private] => [code:protected] => 400 [file:protected] => /home/webs/avidyne/public_html/wp-content/plugins/warranty-calculator/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php [line:protected] => 113 [trace:Exception:private] => Array ( [0] => Array ( [file] =>
afassas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote afassas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 12:05am
Confirmed.  Same result for me from Apple iPad and Safari browser.
Alex Fassas
Avidyne IFD-540
Lynx NGT-9000+
Beech A36
KRGA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2023 at 11:27am
Looks like it may be resolved, now.  Seems to be working fine again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2023 at 8:39am
It would sure be nice if Avidyne could move this site to a secure location like the others. All my browsers are dropping support one by one for http:// web sites anymore. It's becoming a pain to use a separate browser exclusively for this web site.
This page was generated in 0.035 seconds.
