  New Posts New Posts RSS Feed - Ideal Visual approach settings?
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Topic: Ideal Visual approach settings?
    Posted: 06 Jul 2023 at 4:08pm
I’ve been using the default 4° visual approach setting, which seems to work nicely for pattern entry turns, but seems a bit steep for straight in approaches. Perhaps it just my familiarity with 3° ILS approaches.
What settings to others use for Visual approaches with the IFD?
vas4avidyne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vas4avidyne Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 1:19am
4 degrees.
I typically get long straight-in approaches at my home airport (KRHV) when coming from the south and I like the steeper approach so I can stay a bit higher.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 8:29am
I did not like the angle so I set mine to 750ft/min which works out nicely in my airplane.  Pitch over and descend at the top of the green arc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 11:08am
Exactly what I do -- thumbs up!
This page was generated in 0.211 seconds.
