  New Posts New Posts RSS Feed - FPL not syncing
FPL not syncing
djbewick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djbewick Quote  Post ReplyReply Direct Link To This Post Topic: FPL not syncing
    Posted: 18 Jun 2023 at 11:01am
I'm running an IFD100 (10.3.0.2) on an iPad Pro (16.5) and an IDF440 (10.3.1.2) using a PilotAware Network (UK Electronic Conspicuity device a bit like Status) with both iPad and IFD as clients.  Frequency sync works fine, however, FPL doesn't mirror.  As I have confirmed NavData and Obstacle databases are identical on both IFD100 and IFD440, I'm guessing the problem is that the current S/W version for the IFD100 is behind the latest AViOS update to 10.3.1.2, but I've seen comments on here that suggest that others have made this difference in S/W versions work.  Does anyone have any thoughts on what else to check?  I have had this working under the previous 10.3.0.2 AviOS.
ricardo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 10:29pm
the ipad IFD app is at 10.3.0.2 .. that’s what everyone is running.
did you try quitting the IFD100 app and restarting it?
This page was generated in 0.037 seconds.
