  New Posts New Posts RSS Feed - Alert the IFD to an Android device
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Topic: Alert the IFD to an Android device
    Posted: 23 Oct 2022 at 7:23am
Need to trigger the IFD to recognize an Android device so that you'll receive ADS-B in and GPS position on the device?
Currently Avidyne doesn't provide anyway to do this however it is pretty easy to do with the following steps. Note this needs to be done every time the IFD is turned on.
The following is based on the assumption that the IFD is creating the Wi-FI network. On your Android device download the program called "UDP Sender" by Hastarin. Enter the following in the program. Destination IP: 192.168.0.1 Port: 5686, Text: AVISDK and leave Hex blank.
Then to trigger the IFD just hit the send button inside UDP sender and tell the IFD to accept your device in the AUX page, at that point you can startup whatever EFB you want to use on your Android device and as long as you have ADS-B over Wi-Fi enabled you'll get the GPS and ADS-B in (if the IFD is receiving it) telemetry.
If the IFD is a Wi-Fi client to another device such as a stratux then things get a little more complicated but it is doable, just takes a little more effort and know how.
Once you configure UDP sender, it retains the information you programmed in it so you only have to open it and hit send next time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 2:10pm
This might be something that Avidyne may wish to build into the IFD100, or a related app.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 7:18pm
It is built into the IFD100, but the IFD100 is iPad only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2022 at 6:53am
Avidyne has an open job for a mobile software engineer, and Android experience is listed as "desirable." I wouldn't read too much into this-- we won't be getting an Android IFD100 app-- but someone with those skills should be able to knock out an app for the Google Play store just to tickle the connection.
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2022 at 10:59am
I agree this would be a pretty easy application for Avidyne to put out under their name, but for now the work around that I provided works for me and presumably others.
BoeingBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BoeingBoy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2022 at 12:53pm
As I've mentioned on my own thread PA23's work around using UDP sender works well.
An Android IFD100 would complete the Avidyne user experience no end. It's just not acceptable to blatantly favour Apple when their hardware is grossly overpriced, and their software support discontinued to ensure sales are regenerated.
I know a lot of potential customers who've gone 'G' in protest at this policy.
