  New Posts New Posts RSS Feed - Gap in route
Gap in route
frankbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Topic: Gap in route
    Posted: 10 May 2022 at 7:57am
What is the design logic for “gap in route”?  Why not just assume that you’ll want to go direct from the point prior to the “gap” to the next point (which is what you’d almost always want to do)?  Seems like it’s just an extra step to have to eliminate the gap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 8:50am
You hit the nail on the head when you said "almost always".  The FMS doesn't want to assume a path.  It wants the pilot to define that.  There may be an obstacle or terrain that would conflict with a direct leg.  It's best just to involve the pilot to make sure it's OK to go direct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 1:25pm
I do understand that making assumptions can be dangerous, but it seems to me that adding button pushes to an otherwise simple operation (i.e. adding waypoints to a route) is a step backwards.  I don’t think any other box (i.e. the “G” boxes) do that… my 530 didn’t, and never caused a problem.
Not a big issue, just a small irritant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 9:55pm
Personally, I see that as one of many failings of the UI on G* stuff. Give it some time, and you may agree.
Logical GAPs in a flight strip are a standard feature in any FMS.
Edited by oskrypuch - 10 May 2022 at 10:00pm
