  New Posts New Posts RSS Feed - Military Bases, no runways?
JohnAJohnson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnAJohnson Quote  Post ReplyReply Direct Link To This Post Topic: Military Bases, no runways?
    Posted: 08 Aug 2021 at 5:05pm
I haven't been able to figure out how to show the actual airport/runways on military bases.  The Class D or C rings show up, and if there is a VOR in the airspace, it shows up, but the airport and runway symbols do not.  This is true on the IFD100, the Simulator, and on my IFD540 in MAP or FMS views.  Running 10.2.4.1.  Is this normal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnAJohnson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 5:16pm
PA23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 5:44pm
I've never noticed if the runways display at Military bases, however I can conform that the approaches are accessible in the IFD units as I've flow approaches at both WRI and DOV and approaches for both were loaded on the IFD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 6:56pm
Check to see if you are filtering airports by those that have 100LL.  I was able to replicate your results by filtering airports to only those that have 100LL in the AUX-Map Setup - Airport Filter. Returning the fuel airport filter to "Any" restores those airports on the map display as well as keeps those that do not have jet fuel on the map.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnAJohnson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 8:16pm
Originally posted by dmtidler dmtidler wrote:
Check to see if you are filtering airports by those that have 100LL...
That did it.  Thank you!
