  New Posts New Posts RSS Feed - bluetooth ADS-b to IFD100
  FAQ FAQ  Forum Search Search  Register Register  Login Login
rpostmo View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Topic: bluetooth ADS-b to IFD100
    Posted: 13 Nov 2020 at 6:29pm
Is this likely to be an option?
I'd like to use my bluetooth (DUAL Xgps 170D) receiver to
send weather and traffic to the IFD100 app on my Ipad Mini4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 6:43pm
No.
The IFD100 app can only get traffic/weather thru WiFi from the IFD, which can only get data from certified panel devices.
Edited by oskrypuch - 13 Nov 2020 at 6:44pm
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 7:39pm
Thanks for the quick response.
It seems it would be possible through software, or is it
regulatory re: certified/non-certified equipment?
vancinad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vancinad Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2020 at 3:46pm
It would be theoretically possible, but as oskrypuch noted above, the IFD100's sole data source is the stream coming off of the panel device. Taking info from anywhere else would certainly be a certification/approval problem, as you guessed.
Edited by vancinad - 14 Nov 2020 at 3:46pm
