  New Posts New Posts RSS Feed - Wind data block empty
C5testplt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C5testplt Quote  Post ReplyReply Direct Link To This Post Topic: Wind data block empty
    Posted: 02 Nov 2020 at 8:22pm
Well I finally dropped the big bucks (after doing an IFD 540/APX 340/ AMX 240 upgrade 4 yers ago).
I now have an EI MVP 50 and Dual G5’s installed. The extra integration is great
I see the winds displayed on the UTIL-CALCULATOR page, but when I select WIND VECTOR for display on the left data block, it always shows up as dashes. I installed the latest IFD 540 software in May 2020. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 8:08am
To get the wind vector, you need both TAS and heading data. TAS depends on OAT. You didn't say whether your G5s include the OAT probe; if not, that's probably the problem. If you do have OAT on the G5, then I'm out of guesses.
c17testplt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote c17testplt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 10:22pm
Thanks for the reply.  You may have skipped the details.  The IFD already is showing the winds and TAS on the UTIL CALCULATOR page --my OAT is coming from the MVP-50.  It seems odd that the IFD 540 will calculate and show the data on the UTIL pages but NOT when i set them for display on the left data blocks.  Wierd
Knobs
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 8:18am
You're right-- I thought you meant that you could use UTIL-CALCULATOR to figure the winds, which is totally not what you actually wrote.
Since one of the things I most want to work after my Aspen upgrade is the wind vector block, I'm very interested in seeing what you find out.
This page was generated in 6.203 seconds.
