IFD Quality Control? |
GMSutton
Posted: 30 Sep 2020 at 11:49am |
Friends: As an early adopter of the IFD series navigators, I purchased my first IFD540 pre-certification at Oshkosh back in 2012. My first IFD540 worked perfectly from day one. Eight years later, I just swapped the IFD440 in my current airplane for another IFD540.
However, on my first test flight with the brand-new IFD540, the unit repeatedly reset and lost all navigation and flight plan information. The screen went black although the COM function was still active. We landed, checked the connectors, and tried again. This time, the unit reset repeatedly while taxiing on the ground. To verify the problem was internal to the IFD540, the avionics shop swapped the unit for another, which worked perfectly. So my brand-new IFD540 has to go back to the factory for warranty replacement. The avionics shop told me this isn't the first time that has happened. Fortunately, the shop loaned me a demo IFD550 so I could fly my airplane home while awaiting a replacement IFD540 from the factory. God knows how long that will take... My question is: Why isn't there better quality control at Avidyne? The IFD540 has been in production for a long time now, and they've had plenty of time to crack any manufacturing issues. What's going on?
Edited by GMSutton - 30 Sep 2020 at 11:51am |
Infant mortality. If electronics are going to fail, they usually do so very early on, or a long, long time later. * Orest
Edited by oskrypuch - 30 Sep 2020 at 1:51pm |
GMSutton
Thanks. But according to my avionics shop, one of the largest in the Pacific Northwest, "infant mortality" seems far more common in Avidyne products than in those made by other brands such as Garmin...
FlyingCOham
Burn in at the factory, not after customer installation has been SOP for all quality oriented manufacturers since the 70's...
Jim Patton
paulr
I'm not saying anything one way or another about Avidyne or Garmin. I *will* say that the amount of authoritative-sounding bullsh*t I've heard from mechanics and shops in the GA industry is absolutely stunning. I've learned to treat any blanket statement like your shop gave you with a great deal of skepticism.
SB Jim
Senior Member Joined: 30 Aug 2012 Status: Offline Points: 206 |
Just another data point.
My IFD 540 has been flawless since installed in early 2015. My Garmin CNX 80 has been flawless since installed in late 2004. When the Garmin was sent in for a “free” factory software upgrade I was told it had RS-232 port problems and it would be $1,000 to repair it or they refused to return my unit. Honestly. When the IFD 540 needed a factory software upgrade it went in, and came back, and worked perfectly. Without the $1,000 and all the BS. BTW my installation didn’t / doesn’t use the RS 232 port. Garmin didn’t care. They stuck it to me because they could.
MarkZ
The best you can do is sign a lease with Garmin on a time limited product.
Senior Member Joined: 30 Dec 2011 Location: Kingston, NY Status: Offline Points: 726 |
Guys, I've been to the Avidyne manufacturing center in Melbourne and I've witnessed with my own eyes the USA manufacturing of the IFD products. I've seen the pick and place machines manufacture the circuit boards, I've seen the technicians inspect boards under a microscope for flaws, and I've seen the environmental testing equipment that each and every IFD goes through, even the ones sent in for repair. This testing is done before the equipment goes out into the field, both new and repair.
I've had IFDs earlier than anyone, 2-3 years before certification, and I've bricked one during precert testing loading software, but other than that, they have been rock solid. I can tell you that most shops prefer to work with Garmin, and I believe (personal opinion) that skews their opinion of anything non Garmin.
Bob H
Just some general electronic manufacturing comments: 1.
Anecdotal failures do not a trend make. 2.
Burn-in does not eliminate infant mortality. 3.
Manufacturing is a continuous series of process
controls and feedback with constant challenges. 4.
Supply chain management requires constant
monitoring with its own challenges of process control compliance, testing, burn-in
along with supplier qualification of both processes and materials/components. 5.
Ongoing changes to processes, materials, and
suppliers is a way of life. 6. There is no such thing as set it and forget it no matter how long something has been manufactured. Confirmation bias is alive and well within the
industry. It’s like buying a new
car. Suddenly, you notice all the cars
just like yours on the road. Same with
some shops. They only take notice of the
failures of one brand, because of their bias towards another. I’ve seen it first-hand. |
