  New Posts New Posts RSS Feed - Connecting 5 inputs to AMX240
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Topic: Connecting 5 inputs to AMX240
    Posted: 25 May 2020 at 10:39am
Trying to finish up my Aspen MAX/IFD install and we hit a problem - I have 5 inputs to connect but there are only 4 available.  Is there a way to combine two into one or another way to connect 5 inputs.  I have IFD 550, 540, TAS 605/A, Aspen MAX and I need to connect the Voice Alert box for my Gear/Stall Warning system.  I don't really consider any of those to be "optional" so I don't see how the front panel jack input could be used.  Any suggestions?
AZ Flyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 1:13pm
There are issues to be considered when combining audio signals.  It can certainly be done, but not likely using a passive combiner cable.  Some form of mixer would be needed.  See this informative explanation:  https://sound-au.com/articles/audio-mixing.htm
Edited by AZ Flyer - 25 May 2020 at 1:45pm
Stan
EvieCuyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EvieCuyler Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 12:58pm
Hello...two or three things I would remark on the recommended association:
- You would even now require the input resistor from Vo2 to IN2-
- I would not prescribe to drive both earphone speakers by a solitary yield, this would diminish the yield drive and the outcome would most likely be equivalent to not utilizing the gadget in course
You would at present need to assess the presentation of the gadget with this association, since this is out of the specs in the information sheet.
Edited by EvieCuyler - 04 Sep 2020 at 4:52pm
This page was generated in 0.076 seconds.
