  New Posts New Posts RSS Feed - PIN # for Configuration
Flybuddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Topic: PIN # for Configuration
    Posted: 24 Apr 2020 at 11:51am
Trying to configure for a JPI FS 450 fuel flow. From what I see it supposed to be set as C7 for GPS data on the FS 450 and SHADIN FADC on the 232 configuration page in the IFD440.
When I go into maintenance mode and hit the config tab to check the setup, the 440 wants a PIN#. Where do I get that??
I was able to take pics of config pages back in Feb before last software update so the PIN is something new.
The pic of the 232 config page back then was:
CHANL 1  input SHADIN FUEL  output AVIATION
CHANL 2  input SHADIN ADC   output OFF
I think this is correct.
Edited by Flybuddy - 24 Apr 2020 at 1:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2020 at 3:06pm
Update...called tech support and they were able to email a small update file to bypass it. Security PIN was an add on during the last update.
This page was generated in 0.092 seconds.
