  New Posts New Posts RSS Feed - ICAO codes
ICAO codes
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Topic: ICAO codes
    Posted: 19 Apr 2020 at 6:07pm
I have the APX 340 transponder which is 1090 out and the MLB 100 which is 978 in.  I'm still confused as to which ICAO surveillance codes to use in flight plan filing.  I assume I would select B1 because that is ADS-B 1090 out but I don't see a selection for 978 ADS-B in.  Would "E" be my selection as it is for Mode S, ID, Alt, and Squitter?  What codes have others with this setup used?
rpostmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:28pm
Same setup,  B1 and L transponder.
Hope to be B2 soon when the Freeflight RANGR dual frequency becomes available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2020 at 10:53pm
if you have the same setup, why did you select L?  I chose B1 and E.  The L includes some enhanced surveillance that E doesn’t have.  I’d like to get dual band also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpostmo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2020 at 1:34pm
That's a good question, might have done it in error when I first set up the codes in fltplan.
Is the AXP340  Euro compliant with the DAPS code?
CubedRoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CubedRoot Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 10:38am
I have this same question.  I am setting up my airplane in Foreflight, and not sure which ICAO codes to use.
AXP340 and a Skytrax100 here as well.
Sambo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sambo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 9:45pm
Hi I have questions on codes please,
I have a PMA PS8000B audio panel,
IFD540
Lynx L3 NGT9000 transponder
1) G5 AI
1) G5 HSI
What codes would I use please for the ICAO codes?
Shazam😎
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catani Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 10:29pm
This is what I use with my IFD440 and Lynx NGT9000:
Item 10: SBGRY/EB2
(some say Y is not necessary in the US because ATC does not use those frequencies in the US)
Item 18:
PBN/B2C2D2S1  SUR/260B CODE XXXXX (where XXXX is your aircraft's assigned code)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sambo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 11:48pm
Hello, mine does take the Z automatically for item 10 also
What is item 18 codes for please,
Thanks for all your help,
Shazam😎
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catani Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2020 at 1:43pm
The Z code in Item 10 is to flag the use of  NAV/  in Item 18.  Since there's no need for a NAV/ entry in Item 18, there's no need for a Z flag in Item 10.  The PBN codes are to show the RNAV 5, 2 and 1 capability, and the RNP (but not RNP AR) approach capability, that the IFD is certified for.  The SUR/260B in Item 18 is a required entry to show ADS-B 1090 compliance.  It's a different required code if you complied with the FAA's ADS-B rule with a UAT transponder.
