How to break/open squelch |
Post Reply ![]() |
260SE ![]() Newbie ![]() ![]() Joined: 05 Dec 2019 Location: West Lafayette Status: Offline Points: 27 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jan 2020 at 10:06pm |
I feel stupid. IFD-540. Looked in my manual, searched here, searched web, and watched vids. How do I listen to static to see if I can hear weak signals (like distant ATIS or nav aids)?
dmtidler ![]() Senior Member ![]() ![]() Joined: 12 Feb 2016 Location: USA Status: Offline Points: 635 |
IFD com squelch and active VLOC ID audio toggles are found on the AUX-AUDIO tab with Volume Control at LSK 2L selected.
94S ![]() Senior Member ![]() ![]() Joined: 06 Mar 2014 Location: Bismarck, ND Status: Offline Points: 164 |
Push the volume knob to turn squelch on and off.
PA23 ![]() Senior Member ![]() Joined: 12 Oct 2019 Location: MMU Status: Offline Points: 348 |
next is to fix the reception of the radio... mine SUCKS! I'm going to verify it's not the installation by shoving a GNS430W back into the tray, if that works fine (and I expect it will) I'm guessing the radio has to go back for repair. I'm holding out for my annual in 2 months, since the plane has to be down anyway... Oh transmit is fine, ATC can hear me with no issues whatsoever but I can't hear them even if I manually open the squelch. :(
Post Reply ![]() |
