  New Posts New Posts RSS Feed - New Aspen Avionics MAX Upgrade Experience with IFD
donemory View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donemory Quote  Post ReplyReply Direct Link To This Post Topic: New Aspen Avionics MAX Upgrade Experience with IFD
    Posted: 02 Aug 2019 at 11:01am
Just checking to see if anyone with an IFDxxx has upgraded their Aspen Avionics to the new MAX upgrade, available & effective, 7/1/19, and what effect or experience, if any, that the upgrade had on the IFD series, good, indifferent, or bad?  I have an IFD540 recently installed & I just sent off my 3 Aspen units for the MAX upgrade to be completed in August.  I am wondering what to expect?  Thanks.
Don
Don
Fuz16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuz16 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:11pm
I am following this.  I am doing the same upgrade in a few months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:33pm
+1 next month
sltx1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sltx1050 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 1:19am
soon as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fuz16 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 9:08am
Following, mine will be done in a few months.
Please post a pirep when you get it back.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donemory Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 12:05pm
All, my 3 Aspen Units arrive today at Aspen Avionics in Albuquerque, NM facility for the MAX upgrade according to tracking numbers & Aspen.  Aspen says it’s a 10 business day turnaround. So based on this data, it looks to be end of month or 1st of September to do the re-install.  My understanding these units will be ready to go except we will need to run an extra wire to my audio panel for altitude call-outs.  I’ll update all on the final outcome once installation completed & flight tested.
Don
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2019 at 2:31pm
An update would be good.
nrproces View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nrproces Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 10:07am
I was a bit disappointed when I learned that my buggy would be down for a min of 10 days, I have decided to find out if I can delay my upgrade until the winter when I don't fly as much. I will let you know what they say, after the inquiry.
Sauce
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 10:31am
Got my email last night.  Aspen wants my units 9/1!
Robert114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert114 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 3:15pm
My PFD & MFD are also scheduled to go back 9/1. Hoped Aspen would take them one at a time but apparently they both must be done at once. Currently, my IFD 540 calls out “500” feet when I’m descending in the pattern. Anyone know what other altitudes will be called out with the additional wire? They’ll be a lot of “chatter” if it talks every time I drift up or down a couple of hundred feet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 4:05pm
From what I have seen, the max can call out ALTITUDE (as set from your altitude tape) and MINIMUM (as set in your minimum window).  Useful, but not a robust feature set (yet).
It also calls out TERRAIN and OBSTRUCTIONS.
The Max PG is posted on Aspen's web site.
Edited by ddgates - 09 Aug 2019 at 4:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert114 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 6:07pm
My upgrades got pushed back until “October” because of some supplier issue (China tariffs?). My avionics shop says he’s still waiting for August panels to come back. Anyone successful with the Max upgrade?
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2019 at 7:52pm
The screens are brighter and the refresh rate is faster. As for function there is really no change between Aspen and IFD. The GPS passes the same data to the Aspen and the Aspen passes the same data to the IFD that was used before.
Aspen added some features to their screens
1. Banana bar
2, Audio alerts
3. Pop out window for adjustment of baro, Alt, Hdg etc. with bigger numbers that are very easy to see.
The big thing is LESS heat generated by the Aspen units.
Edited by Cruiser - 01 Oct 2019 at 7:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 8:47am
Nice.  Thanks for posting.
Got an email from Aspen yesterday - they still report supply chain issues - and are asking that those who had October upgrade dates but haven't sent in their units to hold until November.  I was supposed to have been earlier but have been slipped several times.  Beginning to wonder, but it sounds like the upgrade is worth doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donemory Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 11:29am
All, well I finally finished in getting the Aspen Max upgrade for my 3 Aspen units although it took 5 weeks instead of 2 as originally stated due to their supply issues.  As of this point, I don’t see any difference how the new upgrade communicates with the IFD540 as compared to before.  I’m still trying to get the altitude audio hooked up though which is one of the new features.  The Aspen Max upgrade did not fix my issue that on final I’m still lined up to the right of course.  My Aspen does show the same on the PFD. Now I’m wondering if my AutoControl III autopilot is the culprit.  It just recently stopped working on a flight (it worked on the To trip but stopped working on the Return trip) as it will not fly heading or GPSS.  Now I can’t continue to problem solve. This might be a blessing to solve my problem however...just don’t know yet as all avionics shops are covered up due to ADSB work so I’m kinda stuck until I have the autopilot looked at!  :-(
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 11:33am
Originally posted by donemory donemory wrote:
...on final I’m still lined up to the right of course...
Try this...
1. Boot into Maintenance Mode
2. Use AUX or touch to get to the Config tab
3. Outer knob to the Main System Config Page
4. Press the knob button
5. Outer knob to the "Appr Roll Steer" item.
6. If the setting is "Enabled", set it to "Disabled".
7. Press the knob button
8. Use AUX or touch to get to the Update tab
9. Press "Done" to boot back into flight mode
Setting Appr Roll Steer to disable will cause the IFD to invalidate roll steering outputs during approach.  It's possible that the autopilot is seeing roll steering and prioritizing it over deviations.
Let us know if that fixes the issue.
