  New Posts New Posts RSS Feed - Amx 240
Amx 240
Rmurphy5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmurphy5 Quote  Post ReplyReply Direct Link To This Post Topic: Amx 240
    Posted: 27 May 2019 at 5:16am
Hi there,  just completed an avidyne install on a beech baron. On the six place intercom all 4 pax come through very quiet and they need headset volume right up to last to hear pilot and Co pilot. All were using bose a20s. Pilot and co pilot works as you would want it to. Any ideas!? Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 7:22am
I have one in my Bonanza and it works great. Have you tried the obvious like adjusting the passenger volume knob on the unit?  Also, if you upgraded from an older system, the headset jacks need to be rewired for stereo and all of the headsets need to be in stereo mode.  Check the Bose headset dip switches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rmurphy5 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 6:32am
Hi Gring - the tip to change the headset setting to stereo did the trick - all positions now hear perfectly and it works great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:08am
Great, you'll find that holds true with most audio panels. Where there is a mismatch between how the airplane is wired vs how the headset is set (mono or stereo), you will hear out of only one ear.
