  New Posts New Posts RSS Feed - IFD550 and Garmin 796
Capt.Caveman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Capt.Caveman Quote  Post ReplyReply Direct Link To This Post Topic: IFD550 and Garmin 796
    Posted: 08 Jul 2019 at 11:01am
What if any info can be shared between the New IFD550 that i just installed and a 796 that i have in the plane already
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 1:45pm
I'm not familiar enough with a 796 to answer.  There are several others on the forum that have similar products, so hopefully they will chime in.
forkauto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forkauto Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2019 at 2:44pm
I have a 550 and a Garmin 696, I have flight plan transfer automatically. That is about it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Capt.Caveman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 12:55pm
Forkauto...which way and how is it accomplished? hardwire? bluetooth? wifi?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 1:39pm
Originally posted by Capt.Caveman Capt.Caveman wrote:
...hardwire? bluetooth? wifi?
Easy to set up the IFD -> 696/796 flight plan transfer. It uses an RS232 link, and works very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote forkauto Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 2:17pm
Yes Garmin sells a harness to wire an RS232 from the GNS430/530 to the 696/796. The Avidyne units use the same wiring.
FlyingCOham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 7:06pm
We put a 4-pin connector in the panel below and left of the yoke.  The pins are +12, Data+, Data-, & Ground.  Put the mating connector on the Garmin harness/cable mentioned above and you've got an a/c powered 696 and automatic flight plan transfer to the 696.  We added a switch to disconnect the Data+ & Data- lines allowing quick separation for those few times we don't want the flight plan to transfer to the 696. easy.
Jim Patton
rolfe_tessem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 2:36pm
As others have said, flight plan and magenta line will transfer (one way). You will not see approach stuff depicted on the map but you will see the waypoints. It works very well.
Rolfe
