  New Posts New Posts RSS Feed - GNS430W to APX340
GNS430W to APX340
dan300 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan300 Quote  Post ReplyReply Direct Link To This Post Topic: GNS430W to APX340
    Posted: 27 Apr 2019 at 1:54pm
The 430W has "ADS-B OUT" or "ADS-B OUT +" for choices to send to the AXP340.
With the 340 set to "Garmin ADSB":
If the 430 is "ADS-B OUT", the 340 sees location info.
If the 430 is "ADS-B OUT +", the 340 does not see location info.
It's my understanding that "ADS-B OUT +" is required from the 430W for certified ADS-B out.
Software versions are the latest on both.
Anybody been thru this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan300 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 9:09pm
My AXP340 is version 3.8, is that higher or lower than 3.12 ?
I think I heard that the version has to be 3.12 or higher to hear Garmin ADSB OUT +
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2019 at 9:32am
3.12 should be higher than 3.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan300 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2019 at 10:55am
Thanks, I've since figured that out and it's the reason for my problem. Need a software upgrade. Has anybody gotten one for an older unit?
This page was generated in 0.080 seconds.
