  New Posts New Posts RSS Feed - S-TEC 3100 & Aspen
S-TEC 3100 & Aspen
AZ Flyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Topic: S-TEC 3100 & Aspen
    Posted: 02 Apr 2019 at 1:26pm
Perhaps others can benefit from what I have learned in the process of exploring an upgrade to the S-TEC 3100 AP.
The current setup, in a TR182, is an IFD540 linked to an Aspen 1000 Pro with GPSS and an S-TEC 30 with altitude hold and electric trim.  So all of the components seemed to be in place for a straightforward upgrade to the 3100 using the existing servos at a consistently-quoted installed cost of about $15,000.
However, I recently came upon this very useful guide that makes it very clear that the currently-available Aspen software does not support all of the functionality of the 3100, and requires additional hardware to even accomplish what is currently available:  http://www.chiefaircraft.com/pdf/S-TEC-3100-TechSpec.pdf.  The limitations of the current Aspen software and additional hardware requirements are explained and shown beginning at page 19.  And, the improved capabilities and significantly simplified hardware setup once the new software version is available are explained and shown beginning at page 22.
And, of course, Aspen always extracts an unlock fee so that would have to be factored in, as well.
So, I have concluded that now is not the time for me to undertake this upgrade but will be content to watch for the long-promised Aspen software update.
Ironically, it appears that the Avidyne DFC90 AP would provide all of the functionality of a 3100 now with an STC and upgade path specifically available for my airplane as presently configured.  But with the DFC90 seeming to be in limbo as to future upgrades, I'm leary of going down that path.
EDIT:  Just learned that the TR182 is NOT on the DFC90 STC so no possibility of going that route.
Edited by AZ Flyer - 15 Apr 2019 at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 12:44pm
The link is broken. Do you know if they just moved it or have chief removed the doc? I can't find docs on their web site ... maybe I'm missing a trick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 5:11pm
The link still works for me, but the pdf may be cached.
Edited by AZ Flyer - 05 Apr 2019 at 5:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 5:23pm
I get a 404 error when I click on the link. Thanks for putting the information on your Google drive. I didn't go as far as requesting access, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2019 at 5:27pm
Because the document is labeled proprietary, I thought better of posting it to Google Drive.  Apparently it is available through Genesys dealers, however, so I would recommend requesting a copy from your Genesys dealer before contemplating the upgrade.
Edited by AZ Flyer - 05 Apr 2019 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 9:53am
Here is a good discussion of the issues involved at Beechtalk:  https://www.beechtalk.com/forums/viewtopic.php?f=21&t=166361.
Apparently, a mere software upgrade to Aspen software version 2.9.1 (when available) is no longer sufficient to provide full functionality between a legacy 1000 Pro and the S-TEC 3100.  An upgrade to the 1000 Pro Max on a scheduled basis is required.  And a 2k software unlock.
Edited by AZ Flyer - 24 Apr 2019 at 7:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 8:05pm
Here is an even more thorough (and illuminating) discussion of the issues involved:  https://www.beechtalk.com/forums/viewtopic.php?f=21&t=166059&start=30
This page was generated in 0.081 seconds.
