  New Posts New Posts RSS Feed - iOS BT phone audio problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Topic: iOS BT phone audio problems?
    Posted: 08 Nov 2018 at 6:16pm
I'm having a strange problem since upgrading my iPhone to iOS 12. The phone is paired with the AMX240. BT music and application sounds play normally. However, phone audio is… inaudible. I can hear the change in sidetone when the phone call connects, but I can't hear the other end of the conversation. I didn't change any settings on the panel post-iOS upgrade, and this used to work fine. Has anyone else run into this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 5:55pm
I had similar problem with the iphone connecting to my Lightspeed headset. What worked was to "Forget Device" in the phone bluetooth setting and pairing it again, it restored the phone call function.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2018 at 6:00pm
There may be an iOS issue indeed. I recently had to unpair my iPhone X from my car and pair it again because it was not connecting right. I blamed my car, but maybe it was the phone itself that had the problem and needed a reset of the connection. I did not have to re-pair my Lightspeed Zulu.
pilotken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pilotken Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2018 at 1:08pm
I had the same problem this week. Lots of crackling, so unpaired both the phone and iPad re-paired  seems to work now.
A little google about “iOS 12 Bluetooth audio problems” shows it’s not an isolated problem. There were some WiFi/Bluetooth fixes in 12.01 so I’d suspect apple introduced a driver issue that’s still lurking
Edited by pilotken - 10 Nov 2018 at 1:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2018 at 6:33pm
I'll try that, thanks. On the day of my last flight in the plane, I dropped the phone and cracked its screen; I've replaced it (so the new phone won't be paired) but haven't had a chance to fly yet. Hopefully this weekend…
This page was generated in 0.045 seconds.
