MLB100 and EX5000C compatibility |
victorbravo
Newbie Joined: 01 Mar 2015 Location: Canada Status: Offline Points: 5 |
Posted: 04 Apr 2015 at 10:50am |
Will the MLB100 ADS-B receiver be compatible with the EX5000C? (I am assuming yes from the press releases).
If yes to the above, will there also be compatibility with existing XM Weather and Skywatch systems or will it be either/or decision? In other words, will operators be able to keep the existing XM and Traffic on the EX500C and add the TIS-B and FIS-B with the MLB100? |
Risky52
Newbie Joined: 15 Aug 2015 Location: California, Md. Status: Offline Points: 14 |
Any update on when MLB-100 data will be able to be displayed on teh EX500C.
Wayne T.
AviSimpson
Still looking to have this available in Q1 2016.
Ibraham
Will EX5000 MFD display ADS-B traffic and weather from Skytrax 100?
AviSimpson
Yes, we are currently working on the software update require for the EX series MFDs to display ADS-B Weather and Traffic.
Ibraham
What about the Garmin GTX 345? any chance it will show ADS-B traffic and weather on the EX5000 sometime in the future?
pilotgeek
Newbie Joined: 15 Sep 2015 Status: Offline Points: 10 |
When do you anticipate this being available for the 5000?
jack.ryans
Newbie Joined: 15 Jul 2016 Location: Phoenix Status: Offline Points: 1 |
I Have a Avidyne EX5000 in a 2005 Corvalis and I have just installed a Garmin GTX 345. The installer advised me that Avidyne is currently working on making adjustments to the EX 5000 software to be able to fully talk to the GTX 345 can you advise when this will be available?
Well we just got a GTX345 ourselves to use for integration testing - so far, no success but it's still early.
However, Release 8.2 is focused on the Avidyne supplied ADS-B devices since those are what we know and those are under our control to ensure we have full access to the data protocols and that they won't change. Therefore, I would not count on Rel 8.2 supporting the GTX345 at this time.
Ibraham
When do you expect Rel 8.2? We just installed IFD440 and Skytrax 100, looking forward to having traffic and weather on the EX5000
Ibraham
Steve/Simpson, I hope it is not as lengthy as the 10.2 as it is only a software update not associated with new hardware certification. |
AviSimpson
I won't speculate a timeframe for approval of 8.2. I will share that it is currently in the top priorities of the in-progress projects. We are well into the stage of creating the software for the release, reviewing the requirements and initial testing.
It is a totally different beast than 10.2 was. There are no hardware components to it, however, that doesn't mean it is necessarily easier.
Ibraham
Great, thank you
Melohn
Senior Member Joined: 11 Dec 2013 Location: PHNL Status: Offline Points: 129 |
You guys know we want this, but no one wants you to make promises you can't keep on dates, particularly when at least one major milestone is not under your direct control.
If there is anything those of us with EX5000s can do to help test, please don't hesitate to ask. |
AviSimpson
Thanks for the offer.
TurboPA30
Senior Member Joined: 18 Sep 2010 Location: 27XS Status: Offline Points: 138 |
same here. Willing to play test-bed.
AviSimpson
We appreciate the offer. At this moment we do not need any external support for the EX update.
jknox
Newbie Joined: 21 Oct 2011 Location: Austin, TX Status: Offline Points: 3 |
I am not as concerned with the schedule for 8.2, as I am what it *will* accomplish.
Can you tell me, since the message structure is more or less standard, will it likewise support the Garmin 345 and the Lynx NGT9000+ ??? I do not want to have to hot-glue an iPad to my windshield, just to get traffic details (ADS-B) from the 345. <G> tnx, jmk |
Ibraham
Steve/Simpson, The whole reason we invested a lot of money last July in the Avidyne IFD 440/AXP340/Skytrax 100 was to get traffic on the EX5000. Avidyne has been promoting the MLB 100 which in now Skytrax 100 for the last couple of years as compatible with the EX5000. Thanks
AviSimpson
We've just about wrapped up the development and have begun flying and lab testing beta versions. Should those go well and we only need to make a few tweaks, then we should be in the final stretch. Best guestimate is September.
Edited by AviSimpson - 24 May 2017 at 9:30am |
ansond
Very cool! More than happy to beta-test... :-)
Melohn
Probably too much to ask for, but any idea as to whether this will work with the GTX345 as an ADS-B source?
AviSimpson
It's possible traffic might work but there will likely be no documented support for the 345.
Melohn
Thank you for the quick reply. I'm assuming this also means no graphical weather or METARs as well? I bet there is significant market for this integration if it is technically feasible, but it's completely understandable if it isn't; after all these displays are more than a decade old at this point.
AviSimpson
The protocol to support weather will likely not be supported.
Ibraham
Is September still a possibility?
Ibraham
Is it looking promising for September?
Ibraham
Is September still a possibility for 8.2?
Ibraham
Why does your website list the EX- series MFD compatible with the Skytrax when it is not yet?ADS-B SkyTrax100Avidyne’s ADS-B SkyTrax100 provides affordable ADS-B solutions for general aviation aircraft equipped with Avidyne IFD440/540 systems and EX-Series MFDs*. http://www.avidyne.com/products/978/index.html |
AviSimpson
The 8.2 Release will not be available, that "guestimate" was ambitious. We are planning for it to be available in Q4 2017. "*Depending on your display configuration. Contact Avidyne for more information, as the list of approved displays is currently being expanded via certification." The above is the 8.2 certification we are working on. |
Ibraham
This was the reason we got the Skytrax/MLB 100 July 2016 to get traffic on the MFD, now you are saying Q4 2017, hopefully this guestimate will come true. |
jblodgett
Groupie Joined: 24 Sep 2013 Status: Offline Points: 62 |
With Navworx now toast, will we ever have hope of weather and traffic from Skytrax on the EX series?
Ibraham
Hopefully Avidyne will have it done as "promised" in Q4 2017
DavidBunin
Your hope level should be unchanged, because the product that requires updating was (and is) the EX series display, not the data receiver. David
Ibraham
Breaking news, Avidyne press release, 3 years in the making and still waiting. The only update is the name change to Skytrax 100
http://www.avidyne.com/news/press.asp?release=302 Lincoln, MA – Thursday, October 9, 2014 – Avidyne Corporation, a leading provider of integrated avionics and safety systems for general aviation aircraft, introduced the MLB100 Datalink Receiver for ADS-B (Automatic Dependent Surveillance-Broadcast) IN. The MLB100 is designed to provide ADS-B traffic and Flight Information System-Broadcast (FIS-B) weather information for display on Avidyne’s new IFD540 and IFD440 FMS/GPS/NAV/COMs, as well as EX600, EX500 and EX5000 Multi-Function Displays (MFD). |
AviSimpson
David is spot on here. Release 8.2 is still happening and is well through the development and testing process.
Ibraham
Ibraham
Any updates? There is only 1 month left in Q4 2017, it would be a very nice Christmas present.
Ibraham
Hello Simpson
I guess Q4 2017 estimate for revision 8.2 did not happen. The whole reason for installing the Skytrax was to have traffic on the EX5000 MFD. If for some reason there are some technical or certification issues that would make it impossible to have that happen, please let us know so we can explore other options that would display traffic on the MFD such as L3 Skywatch traffic. Hope the new year brings joy and much awaited updates
kgrant
Newbie Joined: 15 Dec 2015 Location: Bolivar, MO Status: Offline Points: 32 |
ditto.
AviSimpson
We are very close to the approval. Flight testing for FAA credit should conclude in the coming day(s).
Ibraham
Keeping our fingers crossed, hoping for a quick FAA approval.
Thanks for the update
DavidBunin
Quick is relative. At this point I would have April (Sun N Fun) in mind. If Avidyne is doing for-credit test flights now, it means the final data package has not yet been submitted for approval (since the results of the test flights are a required data report in the submission).
When an applicant submits a data package, the FAA has their standard interval to review it. That is usually 60 days for minor changes and 90 days for major changes. Before the FAA's review interval expires, one of two things is supposed to happen; either they approve the data as-submitted, or they ask the applicant a question about it. If they ask a question, then the applicant has as long as he wants to respond. (The applicant usually is very motivated to respond quickly.) Then a new review 60-90-day clock starts at the FAA for the response that was submitted. Since the applicant never knows if or how many times the FAA will ask for more information, he never really knows how long the approval process will take. You get these "in a perfect world, 60 days" kind of answers, but then people latch on to that thinking it is a knowable thing. |
From your timeline sequence description, David, I would say that April (Sun n Fun) sits in the "in a perfect world" category.
From the perspective of a customer awaiting delivery, I would suggest that end of Q2 (June 30) is a more reasonable expectation and if everything goes perfectly a slightly earlier date is possible. From the time A has FAA approval in hand, there is also a delay until users can implement although in this case that should be relatively short since it appears to be mostly a piece of paper (STC, svc doc, manual update?) that needs to get into users/installers hands.
Ibraham
How did the flight testing go? How close are you to the approval?
avimyers
Admin Group Joined: 18 Oct 2017 Location: Space Coast, FL Status: Offline Points: 8 |
As you know we currently use service providers to provide service to our MFD and PFD products. We are conducting a survey and would like your feedback in an effort to improve those services. If you've used Extant or Duncan please complete the following survey at https://www.surveymonkey.com/r/aviservice. If you've had more than one service interaction please complete multiple surveys. Thank you.
Avimyers
Ibraham
DAYS?
