  New Posts New Posts RSS Feed - Gumdrop Cones
Gumdrop Cones
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Topic: Gumdrop Cones
    Posted: 07 Apr 2017 at 11:12pm
Is there any way to turn off those big-assed blue gumdrop shaped cones that appear over every tower? I was flying a practice approaches today near a windmill farm and dozens of those #$^& blue cones effectively obliterated my IFD screens. There was traffic in the area but it could not be seen due to these things. Very annoying!
I don't see any safety benefit from them and would really like to get rid of them.
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:07am
I would read up a bit on FLTA (forward looking terrain avoidance) in the manual, it is a very valuable feature that really shouldn't be ignored.
But, if you really want to, you will probably find a way to do that with that search.
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 1:01pm
I do not believe this is a FLTA issue. I know how to turn FLTA off (even though I haven't). These are obstacles and they are below my altitude. I have read the manual and I haven't found any way to turn them off.
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 6:36pm
Actually, if it is these "gumdrops" ...
... it is FLTA. FLTA also paints warnings over obstacles. Check out page 3-28 ...
Any obstacle in the database within a 5nm radius of the aircraft
position and whose top is within 2000’ vertically (above or below)
of the aircraft altitude will generate a cyan (blue) threat bubble
over the obstacle on the map pages. Obstacles inside a 3nm
radius of the aircraft position and whose top is between 100’
below aircraft altitude and 1000’ below aircraft altitude will
generate a yellow threat bubble over the obstacle. Obstacles
inside a 1.5nm radius of the aircraft position and whose top is
between 100’ below aircraft to anything above aircraft altitude will
generate a red threat bubble over the obstacle.
Edited by oskrypuch - 08 Apr 2017 at 8:13pm
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:03am
OK. thank you for your help.
I use the 550 as my primary interface/display and the 440 as mostly as just a traffic and FMS display. I'm trying to declutter the 440's tiny display as much as possible (I use the 550 for TAWS, etc). It's interesting that turning off TA and FLTA on the 440 User Setup page does not eliminate the cones. I think I'll try turning on "external TAWS" on the 440 main setup page and see if that eliminates them.
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 3:40pm
Sure, roger that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 5:50pm
FWIW - Turning off FLTA in AUX - SETUP - User Options appears to only suppress the FLTA CAS messages in both the iPad and PC IFD trainers. The FLTA depictions on the MAP (obstacle "gumdrops" and terrain coloring) do not appear to be affected.
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 8:35am
Just to finish off this thread. I have tried everything I can think off and there does not appear to be a way to turn the cones off. I even turned on "external TAWS" in the configuration pages. That is supposed to disable all the IFD TAWS functions. Didn't work. They are very persistent .
On the brighter side, they are a little less overwhelming on the SVS view.
Ron L
This page was generated in 0.112 seconds.
