  New Posts New Posts RSS Feed - Release status?
Release status?
rfriend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfriend Quote  Post ReplyReply Direct Link To This Post Topic: Release status?
    Posted: 15 Mar 2017 at 3:39pm
Wonder if we can get clarification as to status of IFD 100 software:  Being held by Avidyne or awaiting apple for approval to be released ? Called tech support and they did not have any information. Thanks.
pitchristian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pitchristian Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 4:37pm
It's in the apple store approval process per avidyne. That usually takes no more than a week. It should be out this week I would assume.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 8:51am
It is pending approval from Apple, which can take anywhere from 3 to 30 days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 12:50pm
As we anxiously await the IFD100 release from Apple; can anyone confirm that the IFD100 will run on an iPad mini (provided it meets the supported iOS and memory requirements)? The IFD100 QRG doesn't specifically mention the iPad mini as a supported platform; however, doesn't specifically exclude it either.
All of the promotional videos I have seen as well as the Avidyne booth at AirVenture 2016 demonstrate the IFD100 on full size iPads. If the iPad mini is a supported IFD100 platform, then can someone (from Avidyne?) post screenshots or pictures of how the IFD100 app looks on an iPad mini in both portrait and landscape views?
gsxrpilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsxrpilot Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2017 at 10:58am
I don't know of any apps that are dependent on the size of the iPad.  There are certainly some apps that require the functionality of the Pro iPads, but there has never been an app that was only supported on the full size iPads and not on the Mini. I wouldn't expect the IFD100 to be any different.
There are also apps that are supported on the iPhone but not iPad and vice versa.
Paul
Mooney M20K 252
KHYI - San Marcos, TX
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 1:24pm
The IFD100 should work just fine on the mini as long as it is up to date on software.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 1:26pm
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gsxrpilot Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2017 at 10:32am
I'm checking the App Store daily... any clue on the release of the IFD100?
Paul
Mooney M20K 252
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:43am
If you're checking daily, it sounds like you'll be the first to know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:04am
The IFD100 is available in the app store. Here is the direct link:https://appsto.re/us/m4Eqbb.i the user guide can be found here: http://www.avidyne.com/files/downloads/IFD100_User_Guide.pdf
mgrimes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgrimes Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:50am
Thanks, Simpson. I have it downloaded and running on my IPAD Mini and will have a great opportunity this afternoon to flight test it.
Question: Does it matter if the Jepp subscription is not exactly in sync between the IFD100 and the IFD540? For example: Can I load the future March 30th NavData on the IFD100 and have the current NavData on the 540?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:54am
Sounds like finish line to me....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgrimes Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:58am
Should have read the manual first :). Answers my question.
"DIFFERENT NAV DATABASES The IFD100 and the panel installed IFD do not have to have the same cycle navigation database however, the panel installed IFD will not share flight plan information with the IFD100 (or vice versa)"
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:58am
The nav data on the IFD panel unit must exactly match the IFD100.
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 11:58am
Just downloaded it from the App Store.  Unfortunately, still have to get my units upgraded to 10.2 to really test it.
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 12:09pm
Very interesting.  The download from Jepp worked fine, and I am able to load FMS routes and direct-to information, but on my desk without GPS input, it "thinks" we are in Boston.  Very, very neat so far.
Well done!
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote rfriend Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 12:14pm
Thank you,
Question, if I purchase an approach plate subscription from Jeppensen and I only have an ifd 440, will they display on the ifd 100 app when synced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 12:18pm
The initial screen for the IFD100 is a link to Jepp to download the plates/charts/data to the iPad IFD100 App.  The indication for me, once I logged on to Jepp, was that I had an authorized account that could be used for the displayed list of downloads.
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 12:25pm
By the way, someone was asking about displays - I am using an iPad mini that I mount on the yoke of my 182RG. The display of the IFD100 app is very readable and well laid-out.
Edited by AUXAIR - 27 Mar 2017 at 12:27pm
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2017 at 1:17pm
I've just downloaded and started the IFD100 app and logged in using my Jepp JDM id; the one I use for copying navdata to USB for transfer to the IFD540.
However, it comes back with a very strange Jepp serial number that starts with AVD1-..., says that 1 new device is allowed and is Unassigned with No coverage specified.
When I activate it, the list of data sets is presented (like on the IFD Trainer). I can select and download my correct geo coverage (Central Europe) for the current 1703 cycle along with Worldwide Map Data and Europe Terrain. However, I have no option presented to download my subscription chart data (that I currently have in the IFD540).
Should I be calling Jepp about this or Avidyne? If Jepp, what do I need to say to get connected to someone who has a clue about this (my last call there was no one who available who could help)? Apparently there is only one person in Jepp who has any idea and if he is not around then I'm out of luck.
BTW, I'm offline and doing this at home. When I exit the Jepp part and app starts, I can enter a local (Europe) route fine and activate it, but the only chart available is for K02 and it has a big "not for navigation" across it, so it must a single default chart that is a place-holder until valid charts are downloaded.
Edited by chflyer - 27 Mar 2017 at 1:35pm
This page was generated in 0.203 seconds.
