  New Posts New Posts RSS Feed - EVS Camera for 10.2
EVS Camera for 10.2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Topic: EVS Camera for 10.2
    Posted: 12 Apr 2016 at 12:48pm
I thought I'd check into the feasibility of installing an Enhanced Visibility System (EVS) FLIR type camera on my airplane to connect to an IFD540/550 with 10.2.  If found that Astronics Max Viz has several certified camera systems that look to work with the IFDs, with one the OEM option on a Cirrus.
Astronics Max-Viz has several models running from 9k to 25k for the camera.  Here is a link to the website:
www.max-viz.com
Some things I learned:
 - They feel the 320x240 resolution is sufficient for a smaller screen like the IFD540
 - It may not work well through fog or heavy clouds
 - They have heaters to handle icing conditions
 - The more expensive one has a zoom option (using a manual on/off switch
 - The model 600 blends a camera with a light detector so it can show runway lights
Edited by Gring - 12 Apr 2016 at 12:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 1:07pm
I am researching exactly the same thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 2:58pm
We have quite a bit of experience using the MaxViz camera.  It works great but as you note, it's not $ cheap.
We will support any RS-170 protocol camera.  That does include a bunch of FLIR cameras as well as a lot of inexpensive color "lipstick" cameras that use NTSC output format.
