  New Posts New Posts RSS Feed - Emergency Situation
Emergency Situation
GaryB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryB Quote  Post ReplyReply Direct Link To This Post Topic: Emergency Situation
    Posted: 09 Apr 2016 at 8:29am
With either IFD, What would be the quickest,easiest way to change your current routing to proceed direct to the nearest airport?
Sorry if already asked and answered.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 9:09am
Hit the nearest button, select the airport you want from the list and hit "direct to"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 10:50am
Works well on the 540,but My 440 doesn't have a nearest button.
Gary
Jack Seubert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack Seubert Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 11:09am
Jack Seubert
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 11:10am
There still is a nearest (NRST) tab in the FMS groups of tabs, just no bezel key for it.
To access it, hit the FMS button, and click to the right most tab.
Page 2-36 of the PG.
Edited by oskrypuch - 09 Apr 2016 at 11:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack Seubert Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 11:12am
Gary,
If you look on page 2-36 of your pilot guide you will see that on the FMS page there is a NRST tab which you can use to find the nearest airports VOR's etc, just keep pushing the tab until it cycles to airports. Almost as fast as a dedicated button.
Jack
Jack Seubert
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 11:37am
Thanks Jack.
From the MAP tab hit FMS,scroll to NEAREST, Tap the NEAREST BUTTON to scroll thru to the nearest airport,Then Highlight the nearest Airport,hit Direct,ent,ent.
I'm really liking the radios, but this seems like a pretty big flaw. Tough to do in an emergency situation.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2016 at 2:37pm
Don't forget the BT keyboard DOES have a dedicated NRST button. Also, it does work with the current firmware.
