  New Posts New Posts RSS Feed - Intermittent X-Ponder Altitude Issues :-(
cajungene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cajungene Quote  Post ReplyReply Direct Link To This Post Topic: Intermittent X-Ponder Altitude Issues :-(
    Posted: 26 Mar 2016 at 5:11pm
I’m frustrated as hell with Avidyne and feel like I’m a Beta tester for them.  I installed an IFD-540/AXP-340 combo in May 2015. I a few minor glitches, but no issues.  Felt I was home free.
In November 2015 I took the plunge and installed an MLB-100.  The day I picked it up when I took off ATC reported that I was showing an altitude of 64,000’.  After landing back at my avionics shop Avidyne tech support determined that it was an MLB-100 SW issue.  The shop disabled the MLB-100, but on the way back to my home base ATC (Washington TRACON) reported that I had no Mode C altitude.  Recycled and got back home.  Flew a few times with one incident of no Mode C altitude that was fixed by recycling the transponder.  In February I had the MLB-100 patch installed along with the newest patch for the IFD-540.  Flew back home without incident.  On March 10th was trying to get back to my home base and again ATC told me that I had no Mode C, but again I recycled and fixed the issue.
Today, March 26th had the same issue, and recycling didn’t help.  ATC said that my altitude was going in and out.  Now I’m stuck inside the Washington, DC SFRA and have to coordinate with both ATC and Homeland Security in order to get it back to the shop.  I’m not a happy camper.  Don’t expect to spend big, big $$ to have an experimental product.
Couple of questions:
1.        Anyone else having this issue?
2.       Any ideas of what it could be?
3.       Why do I think this is an MLB-100 related issue?
4.       How do I fix it?
I’m so frustrated that I’m about to chuck my whole stack and go with Garmin and let everyone in the world know that Avidyne is not ready for prime time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 5:33pm
Well, you could certainly have a failing transponder. Haven't read about anyone posting of that yet, but it is just electronics.
Note that recycling solid state transponders doesn't usually accomplish anything, though that is usually ATC's first request. I would bet on either a sick encoder, or perhaps an install issue with an intermittent connection somewhere. If the problem is constant, should be easy to track down now, once you get out of the SFRA jail!
Edited by oskrypuch - 26 Mar 2016 at 5:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cajungene Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 1:39pm
Guess the question is where does the AXP get its squawk info? Directly from the encoder or thru the MLB-100 and then to the encoder. Is this an install option so I can have the shop bypass the MLB-100?   All the problems started when the MLP-100 was installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 5:49pm
Well, if you pull the breaker on the MLB100, do you still have Mode C?
The MLB100 does need a PA. I have no idea if the input is/can be paralleled and/or daisychained.
The forums are not an official tech support area, so if you don't get an answer here, give Tech Support a call yourself. I've generally found them to be quite helpful.
Edited by oskrypuch - 27 Mar 2016 at 5:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 6:28pm
I think you're doing Avidyne a disservice with your comments about them not being ready for prime time, given the experience you relate. Avidyne is doing everyone a huge favour with this forum, and Garmin sure as heck isn't taking a risk with something similar allowing everyone to spread their similar Garmin experiences for all the world to hear.
Sure, there were quite a few squawks that arose in the first year after the 540 came out, but that has really quieted down in the last 9 months. You said yourself that you had no issues with the 540/340 combo and it sounds like the current ones are MLB100-related. So throwing out all Avidyne and replacing with Garmin sounds like an over-reaction to me.
A large number of the issues that come up in this forum are installation-related. I'm not familiar with the MLB100, but other threads suggest to me that there are various ways to interconnect MLB100/AXP340/encoder/IFD540. Have you checked the installation manual and the schematics of your installation that were provided by your avionics shop? Your shop did provide you the schematics, didn't they?
Did you notice if GPS reception remained ok? The AXP340 will lose mode C if the GPS feed from the IFD540 drops. It has happened once to me. If that were to happen, it might have come back by the time you were finished recycling the xpdr causing you to think that the recycle fixed the issue.
I suggest you take Orest's advice about contacting tech support directly via phone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2016 at 9:21am
4.       How do I fix it?
Sent you a PM.
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 3:24pm
I'm also having a problem with my mode-c. Got plane back from annual Wednesday and initial contact with atc they said they were not getting my mode c -altitude I guess. Next atc had me recycle the xponder and did not question me after that. Today leaving home airport atc said my altitude was showing ground altitude. I recycled and they said it was still off so I switched to mode a. I have ifd 540, axp322, Tas605 and mlb100. I am at 10.1.2 and mlb 4.10. Any ideas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cajungene Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 7:10pm
Finially appear t have gotten at the root of the problem. Hats off to Avidyne Tech Support. Went out to the airport and went thru some buttonology. One of the key things was to check the air data compute page to see if the altitude shown agreed with the PA on the ground and check the configuration settings. They didn't. When I took it back to the shop that installed it found that the original wiring diagrams for the install were not entirely correct and introduced a loop to the AXP. So sometime it would get the right data and sometimes not. After that they reconfigured it and that appeared to fix the problem. The shop will have to do the work. As an added precaution I also had them put in a new cable to my Xponder antenna since the old cable was 30 years old. Will be testing a lot this week. Check the air data computer page to see if you have this issue. Still sort of bummed that the install Doc's were sort of fuzzy. Have a hanger neighbor who is having similar loop issues since he installed the MLB-100. Not sure why, but the MLB seems to introduce new issues. Never had a problem till it was installed. Hopefully it is fixed for good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 8:38pm
Thanks, Cajungene. I'll check the air data page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2016 at 4:23pm
Glad you got yours working, Gene.  I fly with an MLB, and I fly with a number of other pilots with the same equipment, so I absolutely know that it CAN work properly.  Sorry you had trouble with your installation.
