  New Posts New Posts RSS Feed - CrossSync Error
CrossSync Error
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Topic: CrossSync Error
    Posted: 23 Feb 2016 at 11:55pm
Please see the youtube video link below. Has anyone else seen this behavior with a dual IFD installation after the 10.1.1.0 software update?
I see this at startup. Soft rebooting from the "data update" page does not correct the problem. Powering down with the on/off button and then powering up again does get rid of the error and then everything functions normally. I have an Aspen PFD, DFC90, MLB100 and AXP322.
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 6:52am
Wow...I thought I was the only one seeing that after 10.1.1.  It does not happen all the time.  I have found the powering down EITHER of the 540s will correct the issue.  Avidyne had thought it was an intermittent flightbyte error on my #2 unit but apparently that may not be the case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 6:55am
Yep. If you look at your NAV indicators, you will find that one of them will likely be showing fully deflected down and to the left. Whichever IFD connected to the offending NAV indicator will be the offending unit. The error is because the LIO board inside the unit is booting up out of sequence and affecting the RS232 and other I/O communications.
Call tech support and talk with TJ, he will straighten you out. You'll need to send him your log files, but I'm fairly confident you are seeing the symptoms of the LIO issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 8:12am
Interesting.  I saw a similar issue with my single IFD install the other day after a data update.  When it rebooted after the update was complete, it reported a 429 fault and was not getting the fuel flow data from my engine monitor.  A power cycle of the avionics power bus solved the problem.  Sounds like the root cause might be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 9:32am
There are a few situations that can cause a "cross sync fault" CAS so its always best to check with Tech Support so they can run through some troubleshooting.
With that said, we have identified an issue with Cross Sync that we believe we have a fix for in 10.1.2. We are currently working to have that available.
This issue applies only to dual IFD installations. If you have a single IFD and are receiving "cross sync fault" messages, then you likely have a configuration issue.
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2016 at 7:57pm
OK Steve, I'll see if support can help me.
 Ron
Ron L
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2016 at 1:00am
A more serious problem has developed today. My #1 IFD540's GPS stopped working. Restarting didn't help. Switching antennas with #2 didn't help either. It's dead.
 I'll be talking to the avionics shop Monday but I'm thinking that maybe the GPS was dying a slow death and that may have been causing my recent "CroosSync Fault" issues. Dunno.
Ron L
Royski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Royski Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 10:03am
Ron, I have been dealing with frequent intermittent GPS problems on startup for some time.   The symptoms are zero GPS activity and a 429 input error shown on the screen of 540.   It will persist between re-starts of the 540.
Twice now I've seen that powering off my 340 transponder while the 540 boots will fix the issue.   Looks like you have the remote 322 so maybe try pulling the circuit breaker? Maybe this will help while you wait for a response from Avidyne support.
(I have reported my own problems to the techsupport at avidyne email and have been giving them updates, but have not heard anything back since I uploaded logs three weeks ago.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 4:18pm
I've pinged Tech Support and asked them to follow up with you Roy.
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:58am
Tech support is on it. They have my logs and are working the problem. I suspect I'll be sending it in for repair though.  :-(
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 3:21pm
There is an updated software release (Release 10.1.2) for cross sync issues.
If you are experiencing cross sync issues, please visit your Avidyne dealer for this new update.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 3:42pm
Is this software install a covered expense if done by an Avidyne dealer? There was confusion on 10.1.1 when my dealer said it was not covered but Avidyne said it was.
Edited by teeth6 - 04 Mar 2016 at 3:54pm
