  New Posts New Posts RSS Feed - strange approach
strange approach
luchetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Topic: strange approach
    Posted: 30 Dec 2015 at 3:27am
I will soon get my 540/440 combo and am playing around with the sim so bear with me if I bombard you with questions that might have come up already.
I am based in Zurich hence my examples are all somewhere in Europe. I had the sim load and fly the ILS 28 Y into LIMJ and as you can see from the picture the box generates another 360 turn just before the final approach segment. The Sim will also fly this additional 360.
There is nothing like this on the Jepp Chart ( Varap point) which is also attached so I wonder why this is and if it is just a Sim bug.
Thanks Placido
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 3:38am
here comes the Sim screenshot
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2015 at 11:26am
We'll have a look when we're back in the lab in a few days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 4:18pm
Steve were you able to look into this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 5:20pm
Yes.
The culprit in this approach is the leg from VARAP to D106N (which is the point 14nm from GSE along the 106 radial - reciprocal of the 286 degree inbound course).  In his picture, it's D106P, but you must be using an older database cycle.  That leg is defined as a DF (Direct To Fix) leg, which does not define an inbound course.  So the FMS will try to construct a path from the aircraft position to that point right as VARAP is sequenced.  The path consists of an entry turn and a geodesic path to the point.  The entry turn is computed using the current aircraft course as the starting direction.  The end of the turn is computed as the point along the turn where the geodesic path is tangent to the turn.  *If* the aircraft current course is within two degrees of the course to the waypoint, then the system won't bother generating the entry turn.
In this case, if the aircraft is on path at the hold fix, its course will be 320°.  The course from the hold fix to D106N is ideally 310°, but depending upon the aircraft course when the leg sequences, it could be off of that.  In your screen shots, it is actually 300°.  So even in the ideal situation, the difference between the hold inbound course and the course to D106N is more than the two degrees, so the system tries to compute an entry turn and then a geodesic to D106N.  Because the distance to D106N is so short (roughly a half mile), the system cannot compute the entry turn and a geodesic leg before getting to the waypoint.  So, it generates a nice big circle in order to hit the waypoint.
We're looking at some improvements we can make in the next release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 5:36pm
Ok, sounds very complicated but it seems it raised an issue to correct. BTW why are the intermediate fix designations not like on the plate? and how could I update the database on the sim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2016 at 11:11am
After a thorough database search, it turns out that this is the only approach in the global Jepp database that has the HF-DF leg combination.  We are not planning on making any coding changes to address this special condition at this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2016 at 11:27am
Can you tell us if Jepp & Avidyne have considered adding "Low Enroute" charting to the Jepp ChartView 540-subscriptions?
This and having Track-Up in Jepp charts/airports and automatic Apt Diagram pop-up upon landing would be great additions...
Tom Wolf
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2016 at 11:37am
Yes, we have.  It has resulted in our head spinning due to the amount of effort and complexity it adds.  We keep kicking that enroute chart support can down the road.
Track Up charts is also called Geo-referenced charts.  The database is trying to be updated to support but it's a giant undertaking and will take a long time (not sure how to define "long" here).
One note on the auto airport diagram pop up - if you were flying an approach to the airport and had it up on Chart tab, it will auto toggle to the airport diagram on roll out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2016 at 12:02pm
Did not realize this feature... Geo-referencing both approach chart and Apt diagrams would be a major plus.
Tom Wolf
This page was generated in 0.146 seconds.
