  New Posts New Posts RSS Feed - RNP approval
RNP approval
luchetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Topic: RNP approval
    Posted: 06 Jan 2016 at 4:22pm
I have read some conflicting information regarding the above. Can somebody shed some light?
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 4:54pm
The POH 3-29 clearly states it is not approved for RNP procedures instead AFM supplement says it is approved for RNP procedures, very confusing.
The practical example is that a German airport used to have an approach chart labelled as RNAV approach and now it is labelled as RNP. The DH is labelled as LPV DH. Will the FMS load this approach and are we allowed to fly it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 5:01pm
You need to be more specific with your question. Are you referring to PBN?   The IFD 540 is a GPS navigator with an accuracy down to 0.3.  It is not a DO-236 multi-sensored FMS with RNP alerting.  I asked this question, a few years ago, if it would be possible to achieve RNP with two 540s and the answer that came back from avidyne was no.  I don't think the integrity monitoring is in the architecture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 5:14pm
Tony, I posted a very specific example. If I read the handbook it is clearly stated as not approved if I read the AFM supplement it seems it is approved for terminal RNP approach procedures. The approach plate now is labeled as RNP RWY 32 whereas before it was RNAV (GNSS) RWY 32. Can I fly the approach?
Gary T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2016 at 8:31pm
The latest IFD540 Pilot guide Rev 02 pages 5-27 and 5-28 seem to suggest RNP approaches(certain types) can be achieved.
Gary-T
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 1:01am
Gary, I see it now. I had downloaded my PG maybe 2 months ago and didn't realize it was already old😳
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:34am
Luchetto, I will let avidyne answer the will the 540 do it questions.
The confusion is coming from the term RNP.  The FAA caused this years ago.  It could mean required navigation precision or required navigation performance.  Precision means navigational accuracy, performance means an availability of that nav accuracy which is architecture dependent.
In general if the approached is terps using an SBAS sensor RNAV (GPS) the 540 can legally flight it.  If its an RNP approach (these used to be called SAAR approaches) you cannot legally fly them using the 540.  If the box loads it or not is irrelevant (again an avidyne question).  To legally fly an RNP approach the nav system has to be complaint to DO-283.  The pages reference in the POH is referring to operating rules not MOPS.  I think both the FAA and EASA needs to better clarify this for the pilots.
Can you a link to the approach plate you are referring to?  The fact that you are referring to LPV leads me to believe its a GPS approach.
If you go look at all the approaches for Atlanta (http://airnav.com/airport/KATL)  In my opinion, the 540 cannot legally fly the Z approaches.
Edited by tony - 07 Jan 2016 at 6:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 8:48am
Placido,
Your link seems to be broken. Did you use the globe/link icon to create it? What is the airport?
Edited by chflyer - 07 Jan 2016 at 9:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 9:03am
Originally posted by tony tony wrote:
....or Atlanta (http://airnav.com/airport/KATL)  In my opinion, the 540 cannot legally fly the Z approaches.
And with the cool RTF segments, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 9:46am
Orest, do you mean RF segments (Radius to Fix)? If not, what are RTF segments?
roltman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 9:57am
tony et al.
I think the latest IFR magazine touched on this RNP stuff across the pond.  In Europe LPV GPS approaches are being renamed as RNP approaches, which I think this is what causing some confusion here. While I didn't read the article that closely, I think it's just a name change for those approaches.  In other words there's an expanded meaning to RNP beyond what we know it as w.r.t. FAA and the IFD 540 may be authorized to do those RNP approaches.  Again some more research needs to be done to better characterize it for Europe and I think that's what luchetto was asking.
wookie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wookie Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:24am
Have I missed something?    I didn't think there was WAAS in Europe.   LPV would not apply
without WAAS.   BH
BH
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:32am
I agree. Do you mean the latest (Jan16) IFR mag? It has a comment in the letters section replying to an article on this in the Oct15 IFR mag where it rather vaguely says that authorization is required for all RNP approaches, whether the equipment AFM allows them or not. I say "vaguely" because the IFR article says at the same time that this is due to RF segments which are implied to be on all RNP approaches (may or may not be true). The IFD540/440 AFM specifically says that RF segments are NOT approved.
I would have 2 questions:
1) Does the RNP RWY 32 approach referenced by luchetto include RF segment(s) Yes/No? If Yes, then the IFD is NOT approved per AFM.
2) If No, the IFDxxx IS approved to fly the approach (per the AFM) assuming that there is no "authorization required" statement on the chart. But is the operator approved to fly the RNP RWY 32 approach?
I don't think the answer to 2) is clear, even for US or CA operations. Perhaps someone can provide an authoritative response with reference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 10:50am
Yes, there is WAAS in Europe including LPV approaches. See below.
LSZG RNAV (GNSS) RWY 25
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 12:06pm
I just put an extra T in there.  RTF
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 12:50pm
Just what I thought .... but checking to make sure I hadn't missed a new acronym ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 1:23pm
Agree, since 540/440 not approved for RF segments. Even if it could though, the stopper is the "authorization reguired" note and very few piston aircraft will have the additional kit to get this approval to say nothing about the operator approval too.
Anyone have an example of an approach with RF segment that doesn't have the "authorization required" note?
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 4:56pm
it was the Sylt RNP RWY 32 but for whatever reason it would not take the image.
Placido
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 5:15pm
without WAAS.   BH
There are.  They have their own satellite.  I think they call it SBAS augmentation
clydeps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clydeps Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2016 at 6:02pm
without WAAS.   BH
They call it SBAS in the US too. The WAAS system and the European EGNOS are both Satellite Based Augmentation Systems (SBAS). Several other countries have their own SBAS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 9:22am
Phew, that was a lot of information.
In an attempt to summarize the Avidyne position.....
1.  The FAA is also in the process of calling more and more SBAS operations "RNP".  That is getting very confusing and approaches that used to be RNAV are now being labeled as RNP.   I bet this is going to get more confusing for a while before it stabilizes and we all get used to it.
2.  The IFD pilot guides (e.g. pages 5-27, 5-28 of Rev 02 of the IFD540 manual) try to directly address this.   The IFD boxes are okay to fly many/most RNP approaches but we are not authorized to fly approaches  that contain an RF (Radius-Fix) leg type or state that "Authorization is Required".
Here is a snippet from that section:
RNP/RNAV Operations
The IFD540 complies with the equipment requirements of AC 90-105 and meets the equipment performance and functional requirements to conduct RNP terminal departure and arrival procedures and RNP approach procedures without RF (radius to fix) legs. Part 91 subpart K, 121, 125, 129, and 135 operators require operational approval.
The IFD540 installed with an SBAS approved antenna, provides pilot and automatic flight control guidance for the following operations conducted under instrument flight rules (IFR):
·         VOR, LOC, ILS instrument approach procedures (procedures using VHF radio guidance)
·         RNP instrument approach procedures using the following lines of minima:
o    LNAV minima (including when using advisory vertical guidance from the system);
o    LNAV/VNAV minima;
o    LPV minima; and
o    LP minima.
The IFD540 when installed with a non-SBAS antenna, provides pilot and automatic flight control guidance for the following operations conducted under instrument flight rules (IFR):
·         VOR, LOC, ILS procedures (procedures using VHF radio guidance);
·         RNP instrument approach procedures using LNAV lines of minima only.
The IFD540 complies with requirements of AC 90-100A for RNAV 1 and RNAV 2 operations. In accordance with AC 90-100A, Part 91 (except subpart K) are authorized to fly RNAV 1 and RNAV 2 procedures.
The IFD540 complies with the requirements for GPS Class II oceanic and remote navigation (RNP-10) and (RNP-4) without time limitations. A second navigation source may be required for these operations to meet availability requirements.
3.  Global navigation systems come in several different formats.  We use the GPS constellation which is augmented by several regional additional systems or SBAS.   WAAS, EGNOS, MSAS, GAGNAN aid the GPS constellation as SBAS systems and all are compatible with the IFDs.   Other satellite-based constellations that are NOT compatible with the GPS system are Galileo, GLONASS, Compass.
Here is another note I have in the Pilot Guide to try and address this:
NOTE
Global SBAS Support                                                 Wide area/regional satellite based augmentation system (SBAS) support provided by the IFD include WAAS (Continental US, Alaska, Canada and most of Central America), EGNOS (most of Europe and North Africa), MSAS (Japan) and GAGNAN (India). These are regional augmentations of the GPS satellite constellation and should not be interpreted as meaning the IFD is compatible with other GNSS constellation systems such as Galileo (Europe), GLONASS (Russia), or Compass (China).
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2016 at 2:20pm
Many thanks for this, Steve.
The statement is also in the AFM, which is important because it is an authoritative reference when ramp-checked and the legality of using the IFD540 for IFR approaches is queried, especially in Europe.
The migration of RNAV (GNSS) or RNAV (GPS) approached to RNAV (RNP) is also being seen in Europe, and was the trigger for this thread.
Not wanting to load up with too much more info, but there is a good presentation of this in a Cessna tech briefing: https://tresor.it/s#J58L1shjYCrY5qY7SL_O3w
The most relevant info to this thread is on page 4 and copied below:
There is a secondary question not specifically Avidyne's "problem" which is an operator's authorization to actually make the approach using the approved equipment. There have been considerable discussions on this theme in IFR Magazine and other forums, but the above Cessna note is the clearest and concisest that I've seen.
Any RNAV (GNSS) or RNAV (GPS) approaches that are simply rename to RNAV (RNP) can be flown as before. No change. The ones that cannot be flown at this time are the RNP AR APCH's which are those with RF segments and/or require a higher performance capability (equipment and/or crew) that "requires authorization".
Thanks for your confirmation and focus on the Avidyne statements regarding IFDxxx approvals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 6:12am
RNP/RNAV Operations
o    LNAV/VNAV minima;
o    LPV minima; and
o    LP minima.
NOTE
It seems that there is some FAA movement on this subject with publication of a new AC 90-105A last month, and with RF legs prior to the FAF now ok for Part 91 operations without any additional approval. Eg. KCRQ RNAV (GPS) X RWY 24. This approach is not AR, and is apparently now also in the Garmin GTN database.
There is a discussion on this in the Beech forum here: http://www.beechtalk.com/forums/viewtopic.php?f=21&t=120670. Waiting for the FAA position in writing, but confirmed via phone per one of the forum posts.
When might we expect this to be added to the IFD's?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 9:08am
I know I'm not Steve but here is a response to your question:
TBD. We are currently focused on the Release 10.2 end game. When that is complete, we'll spend more time analyzing recent guidance/policy changes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 6:39pm
Ok, thanks Simpson. Just keep in mind that the G760's have RF RNAV approaches today that the IFD's don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2016 at 6:55pm
G760's ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 3:36am
Sorry, typo, meant GTN 750.
jhbehrens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhbehrens Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 3:01pm
It seems Garmin have now added approval to fly radius to fix (RF) legs to their STC for the GTN series with some limitations, see http://https://bruceair.wordpress.com/2016/03/18/garmin-gtn-avionics-and-rf-legs/
Is Avidyne planning the same for the IFD?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 10:03am
It's on the to-do list.  No assigned release identified yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 5:34am
What is the current status of this? Did support for RF slip in without any notice? What about the AFM update?
Two of the three RNAV approaches used for my home base require RF. All three approaches are proposed in the pull-down list and can be loaded from the current IFD540 navdata database. But these are explicitly not approved in the AFM.
Edited by chflyer - 27 Sep 2016 at 5:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 9:34am
There has been no update to the previous reply from Jake. It's on the list but it hasn't been assigned a release level or date.
swood7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swood7 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 6:23pm
I'm not certain exactly how things are approved for Part 91, but one of my previous airlines helped develop many RNP approaches out here in the Pacific Northwest (and our parent company pioneered the technology in Alaska). In ground school, it was mentioned that we still owned most if not all of those approaches and if another operator wanted Ops Spec approval to use them, those carriers have to pay a lot of money for their use. Obviously we don't use Ops Specs, but if we wanted access to the owned approaches I assume it would be very expensive for us little guys. But as I said, that may not be the case for Part 91 vs Part 121.
As a side note, my Cherokee is in the shop as we speak getting its IFD-440, MLB-100 and AXP340 and I'm beyond excited to pick it up when I get home from this trip.
Sean Wood
hamilton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 8:45pm
Still no movement on this?
It has created quite the issue in New Zealand with our CAA and Airways moving to PBN and RNP.
With no SIDS / STAR our Avidyne operators now have to get radar vectored every time, not all of our hilly country has radar coverage either..........
I don't see us selling another unit until this gets cleared as the competitors products don't have the same limitation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:58am
hamilton, I think you mean RF support.
Avidyne IFDxxx support PBN and RNP (which is simply the new name for what previously were called RNAV (GNSS)), as explained in the exchange above. The official reference is in the AFMS provided by Avidyne with the installation STC. There are many of these in Europe and they are all in my IFD540. Looking at the NZ AIP, I see lots of RNAV SIDs and STARs that should be supported and appear in the Avidyne navdata.
What Avidyne does indeed NOT yet support is RF (radius to fix), and this IS supported by G*. On my IFD540 there are some RNAV approaches requiring RF. These appear nonetheless in the Avidyne navdata, but do not include the full approach via IAF as a pull-down option for selection since these legs require RF. However, there are pull-down options for Vectors and direct to the FAF.
I do agree that this will quickly become a competitive disadvantage as the number of approaches requiring RF is extended. It has started in Europe and is perhaps moving even faster in NZ. However, from a quick check of the NZ AIP I see that all the approaches requiring RF also require operator approval by CAANZ. What is the process to get this and is it achievable for NZ GA piston pilots? In the USA, some RF approaches also require operator approval from the FAA and these normally can't be flown by GA piston pilots either even if they have the G* equipment. In Europe there is an increasing number of RF approaches without any special operator approval needed. These are flyable with G* today, but not with Avidyne.
In any case, it is not the PBN or RNP that is limiting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 3:34pm
Thanks for that chflyer.
NZ is in the process of a phased progression from existing RNAV (GNSS) to RNP, our base here in Hamilton has changed over in the last two months so all RNAV approaches have been in essence renamed.
Our first IFD customer was actually the first GA private operator to gain RNP approval for his aircraft in the country, ironic now that his setup has become the least capable.
With what airways are doing and the slow removal of existing ageing nav aids to fly IFR in NZ you will basically have to be GPS equipped and PBN approved (private with a single box, two for transport).
I do have to give kudos to our CAA for their simplifying the application process for private operators, we thought we were in for a nightmare there like many of the transport operators.
It appears basically anything with an RNP 1 requirement from our NZ AIPs is out, this from Jeppesen;
"What this  means is that, per the source documentation, we have to code these as RNP SID/STAR procedures. Unfortunately not all avionics manufacturers subscribe to RNP SID/STAR procedures. The Avidyne Avionics extract parameters are currently set to exclude RNP SID/STAR procedures. It is the avionics manufacturers responsibility to review their avionics capabilities and then review their extract parameter settings with us to ensure they are getting all procedures which their systems can support. I will send a follow up to my contact at Avidyne, asking him to confirm they do not want RNP SID/STAR procedures included in their NavData subscriptions."
Talking to our IFD customer based here in Hamilton, that takes out all our arrivals and departures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 4:24pm
I would send a private email to Steve Jacobsen and ask him directly to sort this out with Jeppesen. I suggest you attach the Jepp note and copies of the SID/STAR plates that are missing from the IFD540 and ask why they are missing since nothing prevents IFD540 support.
This is not the first time I'm hearing that Avidyne and Jepp don't talk the same language. The AFMS extract quoted by Steve Jacobsen above confirms that Avidyne supports PBN and RNP, so there is no reason for Jepp to not include them on that basis. It is correct that Avidyne do not support RF (and G* do support it). The RNP approach/departure procedures currently published on the official NZ AIP web site (http://www.aip.net.nz/) seem to all require RF and I expect that is what keeps them out of the IFD540 navdata. I don't see any of these for Hamilton in the AIP, though. Perhaps you are using renamed versions of SID/STAR that are not yet published, because I also cannot find any SID/STAR in the AIP that are named RNP. All are named RNAV (GNSS), including those for Hamilton. The plates have a note: "Navigation requirement: RNP 1" which is supported by Avidyne so they should be available. Even if the plates are renamed to RNP, I see no reference on them that would prevent them from being supported by Avidyne and Avidyne definitely needs to make this clear to Jepp, as Jepp has indicated in their note that you quoted.
The RNP approaches which have a "require RF" note will not be supported until Avidyne gets that support added.
Edited by chflyer - 29 Nov 2016 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 4:48pm
Since posting here I did get a reply from Avidyne who are in talks with Jeppesen and the FAA and will advise when they have some information.
On a side note the CNS480 is in the same boat as the Avidyne (run under G* AT) while the GNS and GTN are not and run by G* USA.
We have a 480 operating out of Hamilton also, from the info he has received it almost appears that as the RNP procedures can include RF legs they have excluded all including those that don't.
He said very few in NZ actually contain RF legs, none of the Hamilton procedures do but are still missing.
I think it is partly how our airways have written their data, how Jepp have received and programmed that and then what Avidyne selected, it is obviously different to the states and somewhere along the line it has been excluded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2016 at 5:33pm
Thanks for the additional info re CNS480. The message that you quoted from Jepp essentially says that they have received info from Avidyne to exclude all RNP procedures, even those that don't have RF legs. Based on the AFMS this is outright wrong, so Avidyne definitely need to get it corrected.
There are RNP procedures in Europe that don't include RF legs, and I'll check at the aircraft tomorrow to see if they are in the navdata. An example is Sylt EDXW (Germany). If they are missing then we have the same problem in Europe as you do in Australia.
You may be onto something with your last statement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:16am
I've checked in Germany and found > 10 airfields with multiple RNP approaches, and in some cases only RNP approaches. These are in the IDF540 and are flyable via the sometimes multiple IAFs as pulldown list for selection. None of these approaches have any indicated operator restriction or RF requirement.
So the issue in NZ does seem to be something with the way CAANZ are coding the approaches and the instructions from Avidyne to Jepp. In any case, it's not because the approach is RNP.
NZFlyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NZFlyer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 5:57pm
Regarding the exclusion of New Zealand RNAV(GNSS)SID & RNAV(GNSS)STAR with a note 'Navigational requirements: RNP1', I received the following email from Jeppesen:
'I received additional feedback from Avidyne regarding the below issue. They have confirmed that at this point they do not want us to include RNP SID/STAR procedures in the Avidyne NavData subscriptions. They advised that they are looking into the possibility of doing this in the future but they do not know when these types of procedures may be included.'
The above stance appears to be at variance with the PG. It puts severe operational restrictions within NZ airspace for Avidyne users.
Garmin GTN series appear not to have these procedure exclusions.
I have contacted Avidyne directly and have been put on hold while they deliberate. It looks from the above that they have made up their mind. I just hope that this a communication problem.
Thoughts appreciated.
Sample chart below:
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:49am
Their position is definitely contradictory. First Steve quoted the AFM which specifically lists RNP 1 as approved, and now they don't want Jepp to supply navdata for RNP 1. A bit strange indeed. I hope you get a positive response back soon, as it really eliminates the IFD540 as a viable option in NZ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 3:56pm
The request for Jeppesen to not include the procedures in the database came down from the FAA. At one point we were able to offer them. We are working right now to see what needs to be done on our end (a simple show of compliance, a change in our code or something else).
As soon as we have further clarity on this I will pass it along to you all.
FlyingCOham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 5:03pm
Straight answer, thanks Simpson!!
Jim Patton
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 7:16am
That's insane.  Why would the FAA step in like that?  Why would they even care what your box does or doesn't do in New Zealand?
(I haven't been a big fan of the FAA lately.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote NZFlyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 8:13am
AviSimpson,
Why does this problem affect Avidyne IFD and not Garmin GTN?
Is the problem restricted only to New Zealand RNP 1 procedures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 1:24pm
So the FAA have revoked the approval documented in the POH?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 3:02pm
That seems to be "their jam" lately.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NZFlyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2016 at 10:18pm
Originally posted by NZFlyer NZFlyer wrote:
AviSimpson,
AviSimpson can you please reply to this post. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2016 at 5:03pm
AviSimpson,
We are working to clear up this issue and hope to have a resolution shortly. It has to do with the specific requirements for this type of procedure. There are a limited number of these approaches worldwide so I can't say with any certainty.
When I have more information I will post it here.
This page was generated in 0.103 seconds.
